Editor.Command and Pause token issue
mariusCDZWL
mariusCDZWL
I am trying to invoke POLYLINE command with overriden angle synchronously.
        [CommandMethod("TestPoly")]
        public static void Test()
            Application.DocumentManager.MdiActiveDocument.Editor.Command("_.PLINE", Editor.PauseToken, "<100", Editor.PauseToken);
This works perfectly fine, however if I cancel POLYLINE command with ESC, next time when I try to use the same "TestPoly" command it throws "eInvalidInput" exception.
Is this an API issue or am I doing something wrong?
ActivistInvestor
That looks like a bug. You might try calling the command method with no arguments before calling it with arguments.
More generally, pausing for input has never been considered a reliable way to script AutoCAD.
