Editing multiple files
WPerciful
WPerciful
I wrote a tool to perform a find and replace on the active document.  I’ve been attempting to modify it to allow me to pass the sub a file name so that I can perform the edit to multiple files.  As best I can tell the editor variable I set points to the active document.  I simply can’t figure out how to edit the passed document, and not the open one.
    Private Sub test(fn As String)
        Dim db As Database = New Database(False, True),
            dwgDir As String = System.IO.Path.GetDirectoryName(fn),
            dwgName As String = System.IO.Path.GetFileName(fn),
            DocMgr As DocumentCollection = Application.DocumentManager,
            Doc As Document = DocumentCollectionExtension.Add(DocMgr, fn),
            ed As Editor = Doc.Editor
        Using db
            Try
                db.ReadDwgFile(fn, FileOpenMode.OpenForReadAndWriteNoShare, False, "")
            Catch __unusedException1__ As System.Exception
                Return
            End Try
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim filList As TypedValue() = New TypedValue(0) {New TypedValue(CInt(DxfCode.Start), "TEXT")},
                    Filter As SelectionFilter = New SelectionFilter(filList),
                    Res As PromptSelectionResult = ed.SelectAll(Filter),
                    selSet As SelectionSet = Res.Value
                If selSet IsNot Nothing Then
                    Dim idArray As ObjectId() = selSet.GetObjectIds()
                    Try
                        For Each txtID As ObjectId In idArray
                            Dim txt As DBText = CType(tr.GetObject(txtID, OpenMode.ForWrite), DBText),
                                    wksp As String = txt.BlockName.ToString,
                                    hand As String = txt.Handle.ToString,
                                    val As String = txt.TextString,
                                    locX As String = txt.Position.X.ToString,
                                    locY As String = txt.Position.Y.ToString,
                                    locZ As String = txt.Position.Z.ToString
                            If hand <> Nothing And val <> Nothing And val.Contains(strFind) Then
                                txt.TextString = val.Replace(strFind, strReplace)
                                txt.RecordGraphicsModified(True)
                                tbl.Rows.Add(txt.TextString, val, "DBText", dwgName, hand, wksp, locX, locY, locZ)
                            End If
                        Next
                        tr.Commit()
                    Catch ex As Autodesk.AutoCAD.Runtime.Exception
                        ed.WriteMessage(("Exception: " & ex.Message))
                    Finally
                        tr.Dispose()
                    End Try
                End If
            End Using
                Try
                    Dim filList As TypedValue() = New TypedValue(0) {New TypedValue(CInt(DxfCode.Start), "INSERT")},
                            filter As SelectionFilter = New SelectionFilter(filList),
                                    Res As PromptSelectionResult = ed.SelectAll(filter),
                        For Each blkId As ObjectId In idArray
                            Dim blkRef As BlockReference = CType(tr.GetObject(blkId, OpenMode.ForRead), BlockReference)
                            Dim BLK_n As String = blkRef.Name,
                                    BLK_hand As String = blkRef.Handle.ToString
                            Dim btr As BlockTableRecord = CType(tr.GetObject(blkRef.BlockTableRecord, OpenMode.ForRead), BlockTableRecord)
                            btr.Dispose()
                            Dim attCol As AttributeCollection = blkRef.AttributeCollection
                            If attCol IsNot Nothing Then
                                For Each attId As ObjectId In attCol
                                    Dim att As AttributeReference = CType(tr.GetObject(attId, OpenMode.ForWrite), AttributeReference),
                                            wksp As String = att.BlockName.ToString,
                                            hand As String = att.Handle.ToString,
                                            val As String = att.TextString,
                                            locX As String = att.Position.X.ToString,
                                            locY As String = att.Position.Y.ToString,
                                            locZ As String = att.Position.Z.ToString
                                    If hand <> Nothing And val <> Nothing And BLK_hand <> Nothing And BLK_n <> Nothing And val.Contains(strFind) = True Then
                                        att.TextString = val.Replace(strFind, strReplace)
                                        att.RecordGraphicsModified(True)
                                        tbl.Rows.Add(att.TextString, val, "Attribute", dwgName, hand, wksp, locX, locY, locZ)
                                    End If
                                Next
                            End If
                        Next
                        tr.Commit()
                    End If
                Finally
                    tr.Dispose()
                End Try
            End Using
                Dim filList As TypedValue() = New TypedValue(0) {New TypedValue(CInt(DxfCode.Start), "MTEXT")},
                    Try
                            Dim mtxt As MText = CType(tr.GetObject(txtID, OpenMode.ForWrite), MText),
                                        wksp As String = mtxt.BlockName.ToString,
                                        hand As String = mtxt.Handle.ToString,
                                        val As String = mtxt.Contents.ToString,
                                        locX As String = mtxt.Location.X.ToString,
                                        locY As String = mtxt.Location.Y.ToString,
                                        locZ As String = mtxt.Location.Z.ToString
                            If hand <> Nothing And val <> Nothing And val.Contains(strFind) = True Then
                                mtxt.Contents = val.Replace(strFind, strReplace)
                                mtxt.RecordGraphicsModified(True)
                                tbl.Rows.Add(mtxt.Contents, val, "MText", dwgName, hand, wksp, locX, locY, locZ)
                            End If
                        Next
                        tr.Commit()
                    Finally
                        tr.Dispose()
                    End Try
                End If
            End Using
        End Using
    End Sub
I attempted to approach it differently hoping to resolve the issue, but this code failed too.  It goes through the files but won't update any of them.
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument,
            ed As Editor = doc.Editor,
        Using db
            Try
                db.ReadDwgFile(fn, System.IO.FileShare.Read, False, "")
                ed.WriteMessage(vbLf & "Unable to read drawing file.")
                Return
            End Try
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Using tr
                Dim bt As BlockTable = CType(tr.GetObject(db.BlockTableId, OpenMode.ForWrite), BlockTable)
                Dim btr As BlockTableRecord = CType(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead), BlockTableRecord)
                For Each objId As ObjectId In btr
                    Dim objtyp As String = objId.GetType().ToString,
                            objent As Entity = CType(tr.GetObject(objId, OpenMode.ForWrite), Entity),
                            OBJDXF As String = objent.GetRXClass().DxfName
                    Select Case OBJDXF
                        Case "TEXT"
                            Dim txt As DBText = CType(tr.GetObject(objId, OpenMode.ForWrite), DBText),
                            End If
                        Case "MTEXT"
                            Dim mtxt As MText = CType(tr.GetObject(objId, OpenMode.ForWrite), MText),
                            End If
                        Case "Attribute"
                            Dim att As AttributeReference = CType(tr.GetObject(objId, OpenMode.ForWrite), AttributeReference),
                            If hand <> Nothing And val <> Nothing And hand <> Nothing And val.Contains(strFind) = True Then
                            End If
                    End Select
                Next
                tr.Commit()
                tr.Dispose()
            End Using
        End Using
    End Sub
Wayne Perciful
Founder | Perciful Consulting LLC
Perciful Consulting
_gile
In your second method, after having commited the transaction, you have to save the changes in the database:
db.SaveAs(fn, DwgVersion.Current)
Another thing, you won't get any AttributeReference directly in the model space. you have to get the block references first, and iterate through their AttributeCollection.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
_gile
Here's a quick example (C# but easily convertible).
I'd rather use  a return value and arguments because I do not know where 'tbl', 'strFind' and 'strReplace' are from.
        public List<string[]> FindReplace(string fileName, string find, string replace)
            using (Database db = new Database(false, true))
                try
                    db.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, false, null);
                catch { return null; }
                var log = new List<string[]>();
                var textClass = RXObject.GetClass(typeof(DBText));
                var mtextClass = RXObject.GetClass(typeof(MText));
                var blockRefClass = RXObject.GetClass(typeof(BlockReference));
                using (var tr = db.TransactionManager.StartTransaction())
                    var modelSpace = (BlockTableRecord)tr.GetObject(
                        SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                    foreach (ObjectId id in modelSpace)
                        if (id.ObjectClass.IsDerivedFrom(textClass))
                            var text = (DBText)tr.GetObject(id, OpenMode.ForWrite);
                            var str = text.TextString;
                            var pt = text.Position;
                            text.TextString = str.Replace(find, replace);
                            log.Add(new[] {
                                text.TextString,
                                str,
                                "DBText",
                                Path.GetFileName(fileName),
                                text.Handle.ToString(),
                                text.BlockName,
                                pt.X.ToString(),
                                pt.Y.ToString(),
                                pt.Z.ToString() });
continue; } if (id.ObjectClass.IsDerivedFrom(mtextClass)) { var text = (MText)tr.GetObject(id, OpenMode.ForWrite); var str = text.Contents; var pt = text.Location; text.Contents = str.Replace(find, replace); log.Add(new[] { text.Contents, str, "MText", Path.GetFileName(fileName), text.Handle.ToString(), text.BlockName, pt.X.ToString(), pt.Y.ToString(), pt.Z.ToString() });
continue; } if (id.ObjectClass.IsDerivedFrom(blockRefClass)) { var blockRef = (BlockReference)tr.GetObject(id, OpenMode.ForRead); foreach (ObjectId attId in blockRef.AttributeCollection) { var attRef = (AttributeReference)tr.GetObject(attId, OpenMode.ForWrite); var str = attRef.TextString; var pt = attRef.Position; attRef.TextString = str.Replace(find, replace); log.Add(new[] { attRef.TextString, str, "AttributeReference", Path.GetFileName(fileName), attRef.Handle.ToString(), attRef.BlockName, pt.X.ToString(), pt.Y.ToString(), pt.Z.ToString() }); } } } tr.Commit(); } db.SaveAs(fileName, DwgVersion.Current); return log; } }
Gilles Chanteau
GileCAD
GitHub
WPerciful
I've added that line of code, but it results in a 'eFileError'.  I'm on my office computer, but my app is written on my personal laptop which doesn't have internet access at the moment.  So I retyped the rest of my code so that you can see it.
tbl is set on form load, and the code works.  It's just so I can have a log of the changes.
Dim fdb As New System.Windows.Forms.FolderBrowserDialog,
        strFind As string = txtFind.Text,
        strReplace As string = txtReplace.Text
If (fdb.ShowDialog = Windows.Forms.DialogResult.Ok) Then
        Dim FileEntries As String() = IO.Directory.GetFiles(fdb.SelectedPath, "*.dwg")
        For Each dwg As String In FileEntries
                test(dwg)
        Next
End If
dgv.DataSource = tbl
Wayne Perciful
Perciful Consulting
WPerciful
Merci beaucoup!!!!!
Wayne Perciful
Perciful Consulting
