Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Edit and Continue
Edit and Continue
sgrya1
Message 1 of 10
Edit and Continue
sgrya1
Can I please get some pro tips on how to get Edit and Continue working again.
Interested to know what professional developers use. A designated 32bit computer for coding?
And do you need certain AutoCAD, .NET and VS versions to get it working.
I've stared at the AutoCAD splash screen so many times now that I'm getting tired of it.
Replies (9)
Message 2 of 10
_gile
Hi
It works for me with VS2015 and AutoCAD 2016 or 2017 64 bits.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 10
FRFR1426
A SSD drive.
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 4 of 10
FRFR1426
_gile a écrit :
Hi
It does not work with AutoCAD 2017 N52 (the first version released). You have to install the SP1: http://adndevblog.typepad.com/autocad/2016/07/autocad-2017-sp1-and-net-debugging.html or use AutoCAD 2017.1
And you have to disable the Managed Compatibility Mode in VS debugging options: https://blogs.msdn.microsoft.com/visualstudioalm/2013/10/16/switching-to-managed-compatibility-mode-...
Maxence DELANNOY
Manager
http://wiip.fr
Message 5 of 10
dgorsman
One of the best things you can do is to change your development work process:
Do most of the development in the IDE. Ideally, most of the design work/program logic/etc. would be done before you write a single line of code.
Debug only to confirm operation is as designed.
Don't debug to figure out what method to call, or what properties are available.  Use the documentation and Intellisense.
Walk through the content logically at regular intervals to see if it makes sense.  If you have difficultly, chances are things need breaking into smaller pieces.
Create tests for important conditions, and implement try/catch for potentially critical problems, so you don't get kicked out mid-debug.
When you do find a problem during debugging don't exit, continue through and see what else needs tweaking.
Identifying exploits like loops, common methods, and objects early on is better than trying to refactor later.
Edit and Continue is nice, but don't let it become a crutch.
Message 6 of 10
_gile
I totally agree with @dgorsman.
I said E&C works for me (with the precisions provided by @FRFR1426), because i can get it work, but in fact I don't use it...
Gilles Chanteau
GileCAD
GitHub
Message 7 of 10
FRFR1426
I do not use it either, but it's by habit.
Maxence DELANNOY
Manager
http://wiip.fr
Message 8 of 10
sgrya1
I didn't know about the Service Pack. Thankyou
And a while back followed instructions from http://through-the-interface.typepad.com/through_the_interface/2013/11/debugging-autocad-using-visua... which suggested turning on “Use Managed Compatibility Mode” via Tools –> Options –> Debugging. and Enable native code debugging” from Project –> Properties –> Debug.
These settings were actually preventing Edit and Continue. I've disabled them and now it's working.
And thanks for the advice.
Message 9 of 10
ActivistInvestor
"I've stared at the AutoCAD splash screen so many times now that I'm getting tired of it."
You can add the /nologo command line switch to the debug target you specify in Visual Studio's debug settings. AutoCAD starts a lot faster w/o the splash screen.
Regarding the comments others have made about E&C, I beg to differ. The edit-build-test-debug cycle in AutoCAD development is especially tedious, distracting and disruptive to one's train of thought.
For less experienced programmers where mistakes are many, E&C is priceless, because it's common to have to find and fix each error before the next one can be found.
Message 10 of 10
@_gile what is windows version ,Win 10 or for support enable edit and continue
