Dynamic Input
Dynamic Input
Message 1 of 13
Dynamic Input
1. Is it possible to bring some text to the curser with c# (like with the command distance), which will stay there till the cursor moves?
2. Is it possible to insert an errorsymbol at the cursor like it does the editor if you input the wrong thing?
Replies (12)
Message 2 of 13
Can you post some screen mock-up of what you are trying to do. I'm having a
hard time to visualize this. Also look into the Editor.PointMonitor or
Editor.PointFilter event: they allow you to add a tooltip to the cursor.
Albert
wrote in message news:[email protected]...
Message 3 of 13
I attached an image which is showing what i want to do.
e.g. i want to set some values, afterwords i want to show them like acad soes with command distance.
Maybe .PointMonitor is the right way to do this, but how?
Roland
Message 4 of 13
Look at the AppendToolTipText method. It won't exactly work like the dist
command but somewhat similar.
Albert
Roland
Message 5 of 13
Hi Albert,
i will look at it, but isn't it a little bit confusing that Autodesk makes a new dynamic input and says that you don't need the commandline, and on the other side it is just possible to write something in the commandline and not at the cursor with .NET!?!
Roland
Message 6 of 13
OK, now i have to say that i have no idea how to write a text e.g. "Hello World!" with AppendToolTipText to the cursor with following code?
[code]#region Using directives
using System;
using System.Collections.Generic;
using System.Text;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
#endregion
namespace RSNNAcadApp.Test
public class TestEditor
public TestEditor()
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
string TestString = "Hello World!";
}[/code]
Roland
Message 7 of 13
Ok. I looked at this a bit more and there really isn't any way to accomplish
what you want using supported, documented APIs. There's an undocumented API
that you can use if you are so inclined. Please see below:
using System;
using System.Text;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using System.Threading;
using System.Globalization;
using System.Runtime.InteropServices;
#endregion
public class Test
//this is an undocumented api exported from acad.exe. Use it at your
own risk.
// Setting this flag tells AutoCAD to display the last string output
to the command line
//in the Dynamic Input prompt window (one time only.)
[DllImport("acad.exe",
EntryPoint="?acedSetDynInputDisplayMessage@@YA_N_N@Z")]
private static extern bool acedSetDynInputDisplayMessage(bool
displayMessageOnce);
private double m_dist; //last distance chosen (per-document)
private bool m_firstTime = true; //first invocation of "test"?
(per-document)
//use a non-static command method so the enclosing class (Test) will
be instantiated
//for each document
[CommandMethod("test")]
public void DoIt()
Editor ed =
PromptDistanceOptions opt1 = new PromptDistanceOptions("Abstand
zeigen");
opt1.AllowNegative = false;
opt1.AllowZero = false;
opt1.AllowNone = false;
opt1.UseDashedLine = true;
if (!m_firstTime)
opt1.DefaultValue = m_dist;
PromptDoubleResult res = ed.GetDistance(opt1);
if (res.Status == PromptStatus.OK)
m_dist = res.Value;
ed.WriteMessage(String.Format("Abstand = {0}",
m_dist.ToString()));
acedSetDynInputDisplayMessage(true);
m_firstTime = false;
void MyPointFilter(object sender, PointFilterEventArgs e)
e.Result.ToolTipText = String.Format("Abstand = {0}",
m_dist.ToString());
Hi Albert,
Roland
Message 8 of 13
That works great!!!
I will use it as long as it works 😉
Do you know if there will be a chance to put this in the .NET Wrappers?
Or is it planed to put something like this in the Managed Wrapper Classes of the next Acad-Version, or better, next Service Pack? Message was edited by: RolandF
Message 9 of 13
Note that this C++ API is undocumented and unsupported. Once this API
becomes supported on the C++ API I'm pretty sure we will expose it one way
or another in the .NET API too.
Albert
That works great!!!
Message 10 of 13
Thank you again.
Roland
Message 11 of 13
[DllImport("acad.exe", EntryPoint="?acedSetDynInputDisplayMessage@@YA_N_N@Z")]
 the code Albert showed us doesn't work in AutoCAD 2013 anymore. Does anyone know if there is something new?
Roland
Message 12 of 13
Alexander.Rivilis
[DllImport("accore.dll", EntryPoint="?acedSetDynInputDisplayMessage@@YA_N_N@Z")]
private static extern bool acedSetDynInputDisplayMessage(bool displayMessageOnce);
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 13 of 13
Thank you again 😉
