Dynamic Blocks
Dynamic Blocks
amitnkukanur
Dynamic Blocks
amitnkukanur
Hello to All,
After long time i am coming back to AutoCAD customization from Inventor and Vault.
Scenario:
I have a drawing which has multiple Dynamic Blocks with different values.
I am trying to Insert Specific Blocks and new dwg file at a specified location.
i searched in forum and found few codes but they are operated using mouse points.
These are the two codes i Referred
http://forums.autodesk.com/t5/NET/Code-to-insert-a-dynamic-block-into-the-current-drawing/td-p/27984...
http://forums.autodesk.com/t5/NET/how-to-use-a-Block-Properties-Table-of-a-a-Dynamic-Block-using/m-p...
In either case we should decide which block to insert in which location and creare a new file
Regards
Amit
Senior Software Engineer.
Balaji_Ram
Hi Amit,
Sorry for the delay.
Can you please explain the problem you are having in getting the code from those forum posts to work for you ?
If you do not need the point as an input from the user, you can choose to provide it directly as a Point3d without using the "PromptPointResult".
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
