Dynamic Block Reference Issue
Hello all...
I have a dynamic block that is acting funny and I'm wondering why.
In short, I'm using .Net to set a linear distance parameter value. I'm Using the RecordGraphicsModified(True) Method on the block reference and committing all of the transactions w/o error; however the block reference geometry doesn't update.
what's crazier is that if I copy block reference, the pasted copies DO have the updated geometry.
What's going on?
Are you calling UpdateAnonymousBlocks() on the
dynamic block's BlockTableRecord ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6378661@discussion.autodesk.com...
Hello all...
update.
updated geometry.
What's going on?
Tony -- I'm so glad you responded; you definitely seem to be one of the experts on the forum.
To answer your question, No--I haven't.
I failed to point out a few things before:
1) I'm using AutoCAD 2006 -- don't seem to have that method.
2) When I first create a drawing, insert the blocks, everything works as it should. After I save, close and re-open the drawing, the dynamic blocks stop updating geometry.
In AutoCAD 2006, how were these issues prevented or at least resolved?
I'm not entirely sure how it can be dealt with in 2006, and
it may in fact be a deficiency or limitation that lead to the
addition of the UpdateAnonymousBlocks() method.
Sorry.
wrote in message news:6379440@discussion.autodesk.com...
on the forum.
updating geometry.
Thanks, Tony.
It seems that I got it working.
It required me setting the linear value to the default value and then calling Resetblock for some reason. All in all, although I don't care why, lesson has been learned!
