Dynamic Block Creation
It's possible to create a dynamic block programatically?
I want to create a command that captures differents selection sets of drawing objects and assign them to different Visibility States of a new block deffinition, on run time.
Thanks in advance.
adam.nagy
Autodesk Support
Autodesk Support
Hi there,
As far as I know it's still not possible to create dynamic block definitions programmatically. Sorry. 😞
Just in the unlikely case I misunderstood and you actually want to insert dynamic blocks and set their properties, then this post should be useful: http://through-the-interface.typepad.com/through_the_interface/2009/03/accessing-the-properties-of-a...
Adam Nagy,
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
Thanks for the quick reply Adam,
  I already use that for Block operations on my plugin. I really want a way to create a customized tool for Dynamic Blocks authoring, without using block editor.
