Drawing Template File Location
mordend
mordend
Does anyone know how to access the "Drawing Template File Location" path from options?
I assume its through Application.GetSystemVariable() like the Support file search paths, but I don't know what the system variable name is?
Or is there a way to view a list of the system variable names available to Application.GetSystemVariable()?
_gile
You can get or set the templates folder via the Application.Preferences COM object.
dynamic preferences = Autodesk.AutoCAD.ApplicationServices.Application.Preferences;
string templatePath = preferences.Files.TemplateDWGPath;
or just get it via the TemplatePath environment variable
string templatePath = HostApplicationServices.Current.GetEnvironmentVariable("TemplatePath");
Gilles Chanteau
GileCAD
GitHub
mordend
Works for me, thank you sir.
