Drawing Saveas is not given expected results
Message 1 of 9
Hi all,
Here is a code snippet which is helping me save the file in acad 2000 format, it is working fine, I am facing one minor problem with this, the arrowheads of the dimension are not visible, but the dimensionstyle shows that the arrow head exists, and the whole dimension is one entity( I mean it is not exploded). any suggestions so that I can improve on this, I want the dwg to be saved in 2000 format only, whilst I am constructing it in 2011 through VB.Net.
' ' Start Code
Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim strDWGName As String = saveFileDia.FileName   ' Name and path extracted from SavefileDialog box
acDoc.Database.SaveAs(strDWGName, True, DwgVersion.AC1015, acDoc.Database.SecurityParameters)
' ' Ending of the Code
this is what I see in the drawing
** I tried changing the background color just to see that arrow has changed its color, but it is not the case
But on the same file if I do a dxfout(), then it is coming good I dont see this condition.
Please help me.
Replies (8)
Message 2 of 9
arcticad
Your problem is not the file format. but that annotative dimentioning isn't supported in 2000.
(defun botsbuildbots() (botsbuildbots))
Message 3 of 9
Hey that was quick,
is this what I need to add
acAliDim.Annotative= AnnotativeStates.False
or
acAliDim.Annotative= AnnotativeStates.Notapplicable
Sorry I cant run autocad out of my Company so I am asking this question since you are available, please bear with, in fact I should have trid myself.
Thanks for the quickest help I have ever got.
Message 4 of 9
Hi some how I got acces to autocad,
Sorry to say this I am not able to do it, I tried by the methods that I had hit me,
it is not working,
please help me.
Message 5 of 9
arcticad
Post your Autocad file, the original and the saved as
Message 6 of 9
Message 7 of 9
Hi I have posted my files,
any success with that?
Message 8 of 9
hi please reply...
Message 9 of 9
arcticad
The error you are seeing is not because of anything code related.
It has to do with the drawing failing validation.
This is a known problem. I've seen it since 2008
When a drawing is opened in AutoCAD it checks to see if the file was
last saved with an autodesk product.
The data required for this was not supported in 2000/2004.
The file should open just fine if you were using AutoCAD 2004.
However when you use a newer version then it will require the file to be recovered.
If you notice you can resave the file as a 2010 from the 2000 file in code and there are no issues with the file.
The only fix is to resave the file into the current version.
