DrawableOverrule - making a line look like a rectangle
- I have a simple line overrule - basically created from this post https://www.keanw.com/2009/04/optimized-overruling-in-autocad-2010-using-net.html
- In the original code sample, I wanted to change a line so that it looks like a cylinder. This works perfectly. The circular profile is drawn so that lines now look like cylinders.
- What I now want to do is to use a different profile: instead of extruding a circle along a line, I now want to extrude a flat rectangle etc. (or other such shapes created from polylines) along lines. How can I do this?
- I had originally done this using solid3ds, but ran into performance issues when there were more than 1000 lines which required overruling.
Here is my code:
using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.GraphicsInterface; using Autodesk.AutoCAD.Colors; namespace SampleOverrule { // Review this post // http://through-the-interface.typepad.com/through_the_interface/2009/04/optimized-overruling-in-autocad-2010-using-net.html class LineOverrule : DrawableOverrule { SweepOptions sweepOptions = new SweepOptions(); public LineOverrule() { } public override bool WorldDraw(Drawable drawable, WorldDraw wd) { Line line = drawable as Line; if (line != null && line.Length > 0.0) { using (Autodesk.AutoCAD.DatabaseServices.Polyline rectangle = getRectangle(line)) { using (ExtrudedSurface extrusion = new ExtrudedSurface()) { try { //// the circle works, no problem. // Circle circle = new Circle(line.StartPoint, line.EndPoint - line.StartPoint, 50); // extrusion.CreateExtrudedSurface(circle, line.EndPoint - line.StartPoint, sweepOptions); //// but how can one get the rectangle to work? //// an exception occurs below here: extrusion.CreateExtrudedSurface(rectangle, line.EndPoint - line.StartPoint, sweepOptions); extrusion.WorldDraw(wd); // circle.Dispose(); } catch (System.Exception ex) { } } } } return base.WorldDraw(drawable, wd); } private Autodesk.AutoCAD.DatabaseServices.Polyline getRectangle(Line line) { Autodesk.AutoCAD.DatabaseServices.Polyline polyline = new Autodesk.AutoCAD.DatabaseServices.Polyline(); Point2d basePointForPolyline = new Point2d(0, 0); polyline.AddVertexAt(0, basePointForPolyline, 0, 0, 0); polyline.AddVertexAt(1, new Point2d(100, 0), 0, 0, 0); polyline.AddVertexAt(2, new Point2d(100, 100), 0, 0, 0); polyline.AddVertexAt(3, new Point2d(0, 100), 0, 0, 0); polyline.Closed = true; // how do I manipulate the polyline so that its normal is rotated/moved/transformed so that // it aligns with the direction of the inputted line, which is passed as a parameter? // i.e. ideally there would be a method which does something like this: // polyline.SetNewNormal(line.Delta); // presumably we will have to rotate and transform the polyline manually in order to do that? return polyline; } } } //// And here is the command class using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Runtime; namespace SampleOverrule { public class Commands { [CommandMethod("OverruleLines")] public void OverruleLines() { ObjectOverrule.AddOverrule(RXClass.GetClass(typeof(Line)), new LineOverrule(), true); } } } // Please note, you will have to netload and run the command: OverruleLines to see the overrule working
Any advice on how one and extrude a flat polyline along the line will be much appreciated, especially that which solves performance issues when there are a large number of lines involved.
