DrawableOverrule - making a line look like a rectangle
BKSpurgeon
BKSpurgeon
  • I have a simple line overrule - basically created from this post https://www.keanw.com/2009/04/optimized-overruling-in-autocad-2010-using-net.html
  • In the original code sample, I wanted to change a line so that it looks like a cylinder. This works perfectly. The circular profile is drawn so that lines now look like cylinders.
  • What I now want to do is to use a different profile: instead of extruding a circle along a line, I now want to extrude a flat rectangle etc. (or other such shapes created from polylines) along lines. How can I do this?
  • I had originally done this using solid3ds, but ran into performance issues when there were more than 1000 lines which required overruling.
Here is my code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Colors;
namespace SampleOverrule
    // Review this post
    // http://through-the-interface.typepad.com/through_the_interface/2009/04/optimized-overruling-in-autocad-2010-using-net.html
    class LineOverrule : DrawableOverrule
        SweepOptions sweepOptions = new SweepOptions();
        public LineOverrule()
        public override bool WorldDraw(Drawable drawable, WorldDraw wd)
            Line line = drawable as Line;
            if (line != null && line.Length > 0.0)
                using (Autodesk.AutoCAD.DatabaseServices.Polyline rectangle = getRectangle(line))
                    using (ExtrudedSurface extrusion = new ExtrudedSurface())
                        try
                            //// the circle works, no problem.
                            // Circle circle = new Circle(line.StartPoint, line.EndPoint - line.StartPoint, 50);
                            // extrusion.CreateExtrudedSurface(circle, line.EndPoint - line.StartPoint, sweepOptions);
                            //// but how can one get the rectangle to work?
                            //// an exception occurs below here:
                            extrusion.CreateExtrudedSurface(rectangle, line.EndPoint - line.StartPoint, sweepOptions);
                            extrusion.WorldDraw(wd);
                            // circle.Dispose();
                        catch (System.Exception ex)
            return base.WorldDraw(drawable, wd);
        private Autodesk.AutoCAD.DatabaseServices.Polyline getRectangle(Line line)
            Autodesk.AutoCAD.DatabaseServices.Polyline polyline = new Autodesk.AutoCAD.DatabaseServices.Polyline();
            Point2d basePointForPolyline = new Point2d(0, 0);
            polyline.AddVertexAt(0, basePointForPolyline, 0, 0, 0);
            polyline.AddVertexAt(1, new Point2d(100, 0), 0, 0, 0);
            polyline.AddVertexAt(2, new Point2d(100, 100), 0, 0, 0);
            polyline.AddVertexAt(3, new Point2d(0, 100), 0, 0, 0);
            polyline.Closed = true;
            // how do I manipulate the polyline so that its normal is rotated/moved/transformed so that
            // it aligns with the direction of the inputted line, which is passed as a parameter?
            // i.e. ideally there would be a method which does something like this:
            // polyline.SetNewNormal(line.Delta);
            // presumably we will have to rotate and transform the polyline manually in order to do that?
            return polyline;
//// And here is the command class
    public class Commands
        [CommandMethod("OverruleLines")]
        public void OverruleLines()
            ObjectOverrule.AddOverrule(RXClass.GetClass(typeof(Line)), new LineOverrule(), true);
// Please note, you will have to netload and run the command: OverruleLines to see the overrule working
Any advice on how one and extrude a flat polyline along the line will be much appreciated, especially that which solves performance issues when there are a large number of lines involved.
deepak.a.s.nadig
Modified the WorldDraw from your code as below :
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
                //using (Autodesk.AutoCAD.DatabaseServices.Polyline rectangle = getRectangle(line))
                    try
                        //Circle circle = new Circle(line.StartPoint, line.EndPoint - line.StartPoint, 50);
                        //extrusion.CreateExtrudedSurface(circle, line.EndPoint - line.StartPoint, sweepOptions);
                        double x1 = line.StartPoint.X;
                        double y1 = line.StartPoint.Y;
                        polyline.AddVertexAt(0, new Point2d(x1, y1), 0.0, 0.0, 0.0);
                        polyline.AddVertexAt(1, new Point2d(x1+50, y1), 0.0, 0.0, 0.0);
                        polyline.AddVertexAt(2, new Point2d(x1+50, y1+50), 0.0, 0.0, 0.0);
                        polyline.AddVertexAt(3, new Point2d(x1, y1+50), 0.0, 0.0, 0.0);
                        polyline.Normal = (line.EndPoint - line.StartPoint).TransformBy(ed.CurrentUserCoordinateSystem);
                        extrusion.CreateExtrudedSurface(polyline, (line.EndPoint - line.StartPoint).TransformBy(ed.CurrentUserCoordinateSystem), sweepOptions);
                        polyline.Dispose();
Does this help solve your issue ?
