Drawable Overrule not plotting through viewport.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created a DrawableOverrule which will draw a polyline as a table. This draws and plots fine from model space. When I view it through a paperspace viewport, it still looks good, but when I plot, it doesn't show up at all.
I have tested this on both 2015 and 2016 versions of Civil 3d. Can anybody help with what I am missing?
I have even tried changing my overrule to as simple as drawing a circle and even that will not plot through a paperspace viewport. Here is the simple example which will not plot but shows up fine on the screen and also plots fine from model space (it draws a circle instead of the polyline):
public override bool WorldDraw(Drawable drawable, WorldDraw wd) { var polyline = drawable as Autodesk.AutoCAD.DatabaseServices.Polyline; if (polyline != null && polyline.ObjectId.IsValid) { var labelTable = polyline.ReadClassFromEntity<LabelTable>(); if (labelTable == null) return base.WorldDraw(drawable, wd); wd.Geometry.Circle(labelTable.TableInsertionPoint.ToPoint3d(), 5, Vector3d.ZAxis); return true; } return base.WorldDraw(drawable, wd); }
If it helps, here is my overrule code. It may not make sense out of context, but at least you can see what I'm doing and how I'm drawing the entities.
public override bool WorldDraw(Drawable drawable, WorldDraw wd) { var polyline = drawable as Autodesk.AutoCAD.DatabaseServices.Polyline; if(polyline!=null && polyline.ObjectId.IsValid) { var labelTable = polyline.ReadClassFromEntity<LabelTable>(); if (labelTable == null) return base.WorldDraw(drawable, wd); ILabelTableSettings settings = LabelTableSettings.GetLabelTableSettings(polyline.Database, true); if (settings == null) return base.WorldDraw(drawable, wd); // get intersections that are inside of our polyline var pipesPlugin = PlugInManager.GetPlugIn<PipesPlugIn>(); if(pipesPlugin!=null) { string annotationLayer = "0"; ObjectId annotationLayerId = ObjectId.Null; string tableLayer = "0"; // GetPipeCrossings will consider whether or not a Viewport is part of the labeltable. // GetPipeCrossings will convert intersection points? var crossings = labelTable.GetPipeCrossings(polyline); crossings.Sort((crossing, pipeCrossing) => crossing.IntersectionPoint.X.CompareTo(pipeCrossing.IntersectionPoint.X)); // get xdata values, table insertion point, text height using (var tr = polyline.Database.TransactionManager.StartTransaction()) { var layers = polyline.Database.LayerTableId.GetObject(OpenMode.ForRead) as LayerTable; if(layers!=null) foreach (var layer in layers) { var layerObj = layer.GetObject(OpenMode.ForRead) as LayerTableRecord; if (layerObj!=null && layerObj.Name.EndsWith(settings.AnnotationLayer)) { annotationLayer = layerObj.Name; annotationLayerId = layer; } if (layerObj != null && layerObj.Name.EndsWith(settings.TableLayer)) { tableLayer = layerObj.Name; } } } var acadTable = new Table(); acadTable.SetDatabaseDefaults(); acadTable.Layer = tableLayer; acadTable.Position = labelTable.TableInsertionPoint.ToPoint3d(); var mtext = new MText(); mtext.SetDatabaseDefaults(); mtext.Height = labelTable.TextHeight; var columns = settings.Columns.ToList(); if (crossings.Count > 0) { acadTable.InsertColumns(0, mtext.Height * 12, columns.Count); Enumerable.Range(0, columns.Count ) .ForEach( x => { // get the column from the label table, we read the width and that is all. var myColumn = labelTable.Columns.FirstOrDefault(y => y.GetType() == columns[x].GetType()); // if it doesn't exist, we just put it in there...it's the same reference, but no // worries, once we serialize and then deserialize, i think it will be unique. if (myColumn == null) { myColumn = columns[x]; labelTable.Columns.Add(myColumn); } acadTable.Columns[x].Width = myColumn.WidthFactor*mtext.Height; }); acadTable.InsertRows(0, mtext.Height * settings.RowHeightMultiplier, crossings.Count); // sets up the first row Enumerable.Range(0, columns.Count).ForEach(x => { acadTable.Cells[0, x].TextHeight = mtext.Height*1.2; acadTable.Cells[0, x].TextString = columns[x].Header; acadTable.Rows[0].Height = mtext.Height*1.2*settings.RowHeightMultiplier; }); int row = 1; int crossingLabel = labelTable.StartIndex; var doc = CivilApplication.ActiveDocument; foreach (var crossing in crossings) { // todo: find the crossing by number // crossing index is always first since we set it to Canreorder = false acadTable.Cells[row, 0].TextHeight = mtext.Height; acadTable.Cells[row, 0].TextString = crossingLabel.ToString(); acadTable.Rows[row].Height = mtext.Height*settings.RowHeightMultiplier; for (int i = 1; i < columns.Count; i++) { acadTable.Cells[row, i].TextHeight = mtext.Height; acadTable.Cells[row, i].TextString = columns[i].GetText(crossing); } row++; // do we have an annotation point for this crossing? it will fetch the default if one doesn't exist. var annoPoints = labelTable.GetIntersectionAndAnnotationPoint(crossing.CrossingId); // draw the label on the crossing var leader = new Leader(); leader.SetDatabaseDefaults(); leader.Layer = annotationLayer; leader.AppendVertex(annoPoints.Item1.ToPoint3d()); leader.AppendVertex(annoPoints.Item2.ToPoint3d()); leader.Dimasz = labelTable.TextHeight; leader.Dimscale = 1; leader.WorldDraw(wd); // draw Hex and Text // need text size on LabelTable var hatch = new Hatch(); hatch.SetDatabaseDefaults(); hatch.Layer = annotationLayer; hatch.SetHatchPattern(HatchPatternType.PreDefined, "SOLID"); //hatch.ColorIndex = 1; var loop = new Polyline(); loop.SetDatabaseDefaults(); loop.Layer = annotationLayer; var vector = new Vector2d(labelTable.TextHeight * 1.1, 0); var annoPoint = annoPoints.Item2; loop.AddVertexAt(0, annoPoint.ToPoint2d().Add(vector), 0, 0, 0); vector = vector.RotateBy(2*Math.PI/6); loop.AddVertexAt(1, annoPoint.ToPoint2d().Add(vector), 0, 0, 0); vector = vector.RotateBy(2 * Math.PI / 6); loop.AddVertexAt(2, annoPoint.ToPoint2d().Add(vector), 0, 0, 0); vector = vector.RotateBy(2 * Math.PI / 6); loop.AddVertexAt(3, annoPoint.ToPoint2d().Add(vector), 0, 0, 0); vector = vector.RotateBy(2 * Math.PI / 6); loop.AddVertexAt(4, annoPoint.ToPoint2d().Add(vector), 0, 0, 0); vector = vector.RotateBy(2 * Math.PI / 6); loop.AddVertexAt(5, annoPoint.ToPoint2d().Add(vector), 0, 0, 0); vector = vector.RotateBy(2 * Math.PI / 6); loop.AddVertexAt(6, annoPoint.ToPoint2d().Add(vector), 0, 0, 0); loop.Closed = true; var points = new Point2dCollection(); for (int i = 0; i < loop.NumberOfVertices; i++) { points.Add(loop.GetPoint2dAt(i)); } hatch.AppendLoop(HatchLoopTypes.Default, points, new DoubleCollection()); hatch.EvaluateHatch(false); var color = wd.SubEntityTraits.Color; wd.SubEntityTraits.Color = 247; hatch.WorldDraw(wd); wd.SubEntityTraits.Color = color; wd.Geometry.Polyline(loop, 0, loop.NumberOfVertices); var text = new DBText(); text.SetDatabaseDefaults(); text.Layer = annotationLayer; text.Height = labelTable.TextHeight; text.TextString = crossingLabel.ToString(); text.Position = annoPoint.ToPoint3d(); text.HorizontalMode = TextHorizontalMode.TextAlign; text.Justify = AttachmentPoint.MiddleCenter; text.AlignmentPoint = annoPoint.ToPoint3d(); text.AdjustAlignment(polyline.Database); text.WorldDraw(wd); // increment the label last crossingLabel++; } acadTable.DeleteColumns(acadTable.Columns.Count-1, 1); acadTable.InsertRows(0, mtext.Height*1.5, 1); acadTable.MergeCells(CellRange.Create(acadTable, 0, 0, 0, columns.Count - 1)); acadTable.Cells[0, 0].TextString = "UTILITY CROSSINGS"; acadTable.Cells[0, 0].TextHeight = mtext.Height*1.4; acadTable.Rows[0].Height = mtext.Height*1.4*settings.RowHeightMultiplier; CellRange.Create(acadTable,0,0,acadTable.Rows.Count-1, acadTable.Columns.Count-1).Alignment = CellAlignment.MiddleCenter; acadTable.WorldDraw(wd); return true; } } } return base.WorldDraw(drawable, wd); }
