draw polyline realtime
k005
Advisor Advisor
Message 1 of 13
k005
Hello friends,
I want to make an addition to this code. In that :
From the first point I clicked, it continues to draw the Polyline without leaving the point...
how can I do that?
Thanks in advance to the helpful friend.
 [CommandMethod("HesArea")]
        public void AreaCalc()
            // Prompt the user for 5 points
            Document acDoc = Application.DocumentManager.MdiActiveDocument;
            PromptPointResult pPtRes;
            Point2dCollection colPt = new Point2dCollection();
            PromptPointOptions pPtOpts = new PromptPointOptions("");
            Application.SetSystemVariable("OSMODE", 32 | 1);
            BirimCeviri();
            // Prompt for the first point
            pPtOpts.Message = "\nİlk nokta > ";
            pPtRes = acDoc.Editor.GetPoint(pPtOpts);
            colPt.Add(new Point2d(pPtRes.Value.X, pPtRes.Value.Y));
            // Exit if the user presses ESC or cancels the command
            if (pPtRes.Status == PromptStatus.Cancel) return;
            pPtOpts.Message = "\ndiğer nokta >";
            pPtOpts.UseBasePoint = true;
            pPtOpts.AllowNone = true;
            while (true)
                // Use the previous point as the base point
                pPtOpts.BasePoint = pPtRes.Value;
                // Break the loop if the user does not specify a point
                if (pPtRes.Status != PromptStatus.OK)
                    break;
            using (Polyline acPoly = new Polyline())
                int i = 0;
                foreach (Point2d point in colPt)
                    acPoly.AddVertexAt(i, point, 0, 0, 0);
                // Close the polyline
                acPoly.Closed = true;
                double al1 = acPoly.Area / Durum.BolenA;
                double cv1 = acPoly.Length / Durum.Bolen;
                string aLNSonuc = string.Format("\nAlan   : {1}          Uzunluk : {2}",
                Environment.NewLine, al1.ToString("F3") + " m²", cv1.ToString("F3") + " m");
                System.Windows.Forms.MessageBox.Show(aLNSonuc, "Sonuç");
                YaziOlustur("Alan : " + al1.ToString("F2") + " m²     Uzunluk : " + cv1.ToString("F2") + " m");
Replies (12)
Message 2 of 13
Norman_Yuan
You probably want to study the topic of "Jig". Searching this forum and/or the net would bring you plenty of sample code to get started with.
Norman Yuan
Drive CAD With Code
Message 3 of 13
k005
Thanks. I will search
Message 4 of 13
k005
I did it this way. However, the polyline does not appear on the screen.
    Database acCurDb = acDoc.Database;
    Editor acEd = acDoc.Editor;
    BirimCeviri();
    while (true)
            break;
    // Start a transaction
    using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
        // Open the BlockTable for read
        BlockTable acBlkTbl;
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
                                      OpenMode.ForRead) as BlockTable;
        // Open the BlockTableRecord for write
        BlockTableRecord acBlkTblRec;
        acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace],
                                        OpenMode.ForWrite) as BlockTableRecord;
            int i = 0;
            // Add the polyline to the drawing
            acBlkTblRec.AppendEntity(acPoly);
            acTrans.AddNewlyCreatedDBObject(acPoly, true);
        // Commit the changes and dispose of the transaction
        acTrans.Commit();
Message 5 of 13
kerry_w_brown
Perhaps try incrementing the vertex node index  i  in the foreach statement
Perhaps try something like :  ( untested )
acPoly.AddVertexAt(i++, point, 0, 0, 0);
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 6 of 13
k005
I tried it in both code blocks. It didn't work. I couldn't see any polylines on the screen. . He didn't draw. It just catches the point and continues... 😞
Message 7 of 13
kerry_w_brown
This works for me.
I've commented out unnecessary code . . .
The code is essentially your last posted code with iteration of the vertex index in the foreach block in line 60
( as I previously posted )
and translation of the prompts to English.
      [CommandMethod("Answer_1209")]
         ////BirimCeviri();
         pPtOpts.Message = "\nDraw Polyline First point > ";
         pPtOpts.Message = "\nNextPoint >";
         while (true)
               break;
               int i = 0;
            acTrans.Commit();
Message 8 of 13
k005
I compiled the code you sent. But the problem is;
When I click on the first point and then click on the second point, I should see the polyline between the two points... Not when it ends...
Message 9 of 13
kerry_w_brown
@k005 ,
Then do as suggested by @Norman_Yuan , build a jig.
If you study the code you posted you will easily see that it is not designed as a jig, but as a simple procedural method.  ie collect all the points , then create a closed polyline using the points.
There are many jig examples available in various forums and blogs.
This forum has several ( search Polyline jig )
Kean Walmsley has several
TheSwamp has several
forums.augi.com has several
Github has several
Perhaps a Google search for something like "Polyline jig AutoCAD C#" would be a good start
or try ChatGPT
Message 10 of 13
k005
Ok. Thanks.
Message 11 of 13
k005
My goal is for the first code I sent to work like in this video...
Message 12 of 13
_gile
You should be able to draw inspiration from this answer.
Gilles Chanteau
GileCAD
GitHub
Message 13 of 13
k005
Yes, I compiled the code. This is the code I'm looking for. Thank you master.
* I'll try merging it with my previous code.
I combined it. 🙂  🤗
