Draw highlighted line using a DrawJig
fehrsZBFB9
fehrsZBFB9
Hallo Guys,
I've implemented a DrawJig which draws a line in its ViewportDraw-Method. I want this line to be highlighted. Is this possible?
I got it working with but I would like to use the Jig to do it. Is this possible?
TransientManager.CurrentTransientManager.AddTransient(
   line,
   TransientDrawingMode.Highlight,
   128,
   viewportIds
ActivistInvestor
In your previous post, you said you wanted the line to look like a rubber-band.
Please clarify, do you mean a rubber-band cursor or a highlighted entity?  In general, a rubber-band cursor is drawn the way AutoCAD draws them for most operations that involve dragging from a base point.
You say that the basepoint is constantly changing, which is fine in some specialized use-cases. You can set the BasePoint in each call to the Sampler() override to whatever you want, but in my own uses of Jigs, where the basepoint is not fixed, I just use a CursorType of RubberBand to draw a rubber-band cursor from the basepoint to the current cursor position.
In the clip below, the JigPromptPointOptions.BasePoint property is continuously updated on each call to Sampler() to be at the closest point on a curve to the current cursor position.
daniel_cadext
Blue command line?
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
ActivistInvestor
My command line has been that way for as long as it's been configurable.😎
fehrsZBFB9
Hi. I'm talking about highlighting NON-Database resident Curves. The highlighted curve is the nearest to the current cursor position, so it's changing. I currently use a TransientManager to do so but if I have the DrawJig-Method anyway I thought it could be possible doing it there. But I haven't found any options. I assume the highlighting effect is applied later and not through World- or ViewportDraw.
I think I could use an EntityJig but it takes only ONE-Entity on construction. It is not possible to switch it later.
