Download AutoCAD .NET API Labs!
KrishnaK
Archived Account
Message 1 of 13
KrishnaK
Archived Account
Due to overwhelming requests, we have decided to post the AutoCAD .NET API labs that we use to teach the class. This is the best place to start regardless of whether or not you have experience with other programming environments like ObjectARX, ActiveX or LISP. Since the .NET API as it stands today is a wrapper around ObjectARX, an ObjectARX programmer would find it a little easy to transition. That doesn't mean one cannot jump straight into the .NET API. The material takes you through in a "finish a step and see results" way that even beginners will not be lost.
Please note that the material is not 100% error free. Any feedback or suggestions to improve is most welcome.
The material covered in VB.NET and C# is identical.
Krishna Kalvai
Developer Technical Services
Autodesk Message was edited by: KrishnaK
Replies (12)
Message 2 of 13
Very nice. Thank you.
Tim Riley
wrote in message news:[email protected]...
straight into the NET API. The material takes you through i
lost.
Krishna Kalvai
Message 3 of 13
Excellent! Nice gesture!
Ed
lost.
Krishna Kalvai
Message 4 of 13
Excellent Autodesk!
J. Daniel Smith,
See this is a place to learn C# and AutoCAD. If this discussion group is to
academic for you -- stay out!. To other readers, J. Daniel Smith tends to
direct people to other sites when she/he doesn't want to give an intelligent
answer to a question.
Edward
lost.
Krishna Kalvai
Message 5 of 13
Krishna,
These are fantastic! I'm going through them right now and I wanted to
point out one clarification:
In Step 3, Part 1, I think you need to add an Imports statement for
Autodesk.AutoCAD.DatabaseServices in order to get the Circle, BTR, and
BT objects. I was continuing with the same project from Step 2 (Lab 2)
as suggested, and it didn't have this.
Hope that helps and thanks again!
-Danny Polkinhorn
WATG
Honolulu
Message 6 of 13
And then I notice that farther down in the document it says that.
Sorry,
Danny
Danny P. wrote:
> Krishna,
> -Danny Polkinhorn
> WATG
> Honolulu
Message 7 of 13
Thank you!
Roland
Message 8 of 13
I'll say thank you too.
Autodesk needs to get serious about respecting its customers and this is as
good a start as any.
<%= Clinton Gallagher
METROmilwaukee (sm) "A Regional Information Service"
NET csgallagher AT metromilwaukee.com
URL http://metromilwaukee.com/
URL http://clintongallagher.metromilwaukee.com/
lost.
Krishna Kalvai
Message 9 of 13
Does this Lab can run with VB.Net 2003 And AutoCAD 2006 ?
My problem is in lab 5,change MText Object to Block Attribute,Now should be able to insert the EmployeeBlock with INSERT command and specify the employee name for each instance, but i my case it can't.
some one give me a hand?
Message 10 of 13
Very nice! Thank you.
Message 11 of 13
THank you so much after coming to this site i got to know what to do and where to start
Message 12 of 13
_gile
The labs linked in the first message are quite old.
You'll find more recent ones here (Learning > AutoCAD 201X .NET Training)
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 13 of 13
BKSpurgeon
hi thank you.
is there a place where i can post questions about the labs?
FEEDBACK:
yes i did find a few errors in there.
it is somewhat helpful. but the explanations i find, are lacking in thoroughness. e.g. when calling methods there is no explanation of: what the method does, and the meaning of certain parameter inputs. e.g. addNewlyCreatedDBObject has a bool parameter. no explanation is given about the meaning of a 'true" argument passed to this method.
furthermore, the documentation is nowhere near the standard of C# MSDN help libraries out there, so it's very difficult for a noob to truly understand what is going on.
e.g. what is a block reference and why are we adding it to our blocktable record? also early in the lab a block table record is created without a block table first been instantiated.
