Does not contain a public definition for 'GetEnumerator'
Hi all,
While I tried to start a loop on a selection set object as below,
foreach (AcadObject SelDrawingObject1 in GenSelSSetObj)
I get an error as below,
foreach statement cannot operate on variables of type 'Autodesk.AutoCAD.Interop.Common.AcadObject' because 'Autodesk.AutoCAD.Interop.Common.AcadObject' does not contain a public definition for 'GetEnumerator'
Please  help me with changes required to fix this.
Hallex
Try use AcadEntity instead ,in example, this one is from my oldies
  <CommandMethod("DISC", CommandFlags.Modal Or CommandFlags.Session)> _
    Public Sub InteropDemo()
        Dim miss As Object = Type.Missing
        Dim AcadApp As AcadApplication = New Autodesk.AutoCAD.Interop.AcadApplication()
        AcadApp.Visible = True
        AcadApp.WindowState = AcWindowState.acMax
        Dim adoc As AcadDocument = AcadApp.Documents.Open("c:\test\WorkingDrawing.dwg")
        adoc.Application.ZoomExtents()
        Dim util As AcadUtility = adoc.Utility
        Dim oSset As AcadSelectionSet = adoc.SelectionSets.Add("mySset")
        '  get current tab name
        Dim layout As Object = adoc.GetVariable("ctab")
        '  using filter
        '  important: use short[] for dxf codes:
        Dim dxfcode As Short() = New Short() {0, 66, 410}
        '  use object[] for dxf values:
        Dim dxfvalue As Object() = New Object() {"insert", 1, layout}
        '  select all attributed block instances in the current tab
        oSset.Select(AcSelect.acSelectionSetAll, miss, miss, DirectCast(dxfcode, Object), DirectCast(dxfvalue, Object))
        '  send  message to the command line:
        adoc.Utility.Prompt(String.Format(vbLf & "Selected: {0} objects", oSset.Count))
        For Each ent As AcadEntity In oSset
            '  important: cast if AcadEntity is AcadBlockReference
            Dim oblkRef As AcadBlockReference = TryCast(ent, AcadBlockReference)
            If oblkRef IsNot Nothing Then
                util.Prompt(String.Format(vbLf & "Block Name:" & vbTab & "{0}", oblkRef.Name))
                Dim attVar As Object = oblkRef.GetAttributes()
                '  important: cast if object is array
                If attVar.GetType().IsArray Then
                    Dim attColl As Object() = TryCast(DirectCast(attVar, Object()), Object())
                    If attColl IsNot Nothing Then
                        For i As Integer = attColl.GetLowerBound(0) To attColl.GetUpperBound(0)
                            '  important: cast if object is AcadAttributeReference
                            Dim attRef As AcadAttributeReference = TryCast(attColl(i), AcadAttributeReference)
                            If attRef IsNot Nothing Then
                                util.Prompt(String.Format(vbLf & "Tag:   {0}" & vbTab & "Value:   {1}", attRef.TagString, attRef.TextString))
                            End If
                        Next
                    End If
                End If
            End If
        Next
    End Sub
Change file name etc to your needs
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Hallex,
Thanks for you code.
I changed the type from AcadObject to AcadEntity below and also GenSelSSetOb type to AcadSelectionSet
foreach(AcadEntity SelDrawingObject1 in GenSelSSetObj)
Fixed!
Hallex
Good for you
Glad I could help
Cheers Smiley Happy
~'J'~
