Does CAD development has plugin like revit's "addinmanager" for help debug,avoid restart cad
funtim41
funtim41
Does CAD development has plugin like revit's "addinmanager" for help debug,avoid restart cad.
kerry_w_brown
This may be what you're looking for :
https://github.com/search?q=repo%3Achuongmep%2FCadAddinManager%20Mono&type=code
I haven't tried it, I just use Hot-Reload from VisualStudio
https://learn.microsoft.com/en-us/visualstudio/debugger/hot-reload?view=vs-2022
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
funtim41
yes i try to use CADAddinManager,but it does not work.
And hot-reload does not work sometimes too.
Thank you advice
kerry_w_brown
Thank you advice
Hot -Reload works as documented.
There are some changes that can DO require a restart.
The documentation covers the specifics.
