Display of Proxygraphics when saving dwg using ReadDwgFile?
mobj
mobj
I want to handle multiple DWG files containing MagiCAD proxy elements.
An easy and very fast method is to access the files using the ReadDwgFile
Database db = new Database(false, true);
using (db)
db.ReadDwgFile(dwgfile.FullName,FileOpenMode.OpenForReadAndAllShare,true,null); // open the dwg file
 And then save the files using:
db.RetainOriginalThumbnailBitmap = true;    // retains thumbnail previw image
db.SaveAs(dwgfile.FullName, true, DwgVersion.AC1024, null);
 However, when using this method, the display of MagiCAD proxy entities are not saved. The DWG fil still contains the proxy entities, it's just the AutoCAD representation of the elements that have been altered.
Is there a method to handle 3rd party applications when using the .ReadDwgFile?
Morten Bastue Jacobsen
Rambøll Danmark A/S
www.ramboll.dk
artc2
Is the MagiCAD application loaded when the save is done so that the custom entities are not proxies at the time of save?  If not, then whatever proxy graphics those entities had in the dwg file when it was opened will be saved back out again since there isn't any application to create new proxy graphics.
mobj
Yes, the MagiCAD application is loaded before processing the files.
To be more specific: Proxy elements are shown in the saved file, they are just showed differently. I've attached two dwg files. Before and after the .saveas.
here is the code used:
[CommandMethod("RDKPURGEMATERIALS", CommandFlags.Session)]
        public void cmdRdkPurgeMaterials()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            int materialsCount;
            PromptStringOptions pStrOpts = new PromptStringOptions("\nEnter filepath: ");
            pStrOpts.AllowSpaces = true;
            PromptResult pStrRes = ed.GetString(pStrOpts);
            if (pStrRes.Status == PromptStatus.OK)  // check valid string input
                ed.WriteMessage("Filepath is: {0}", pStrRes.StringResult);
                string filepath = pStrRes.StringResult;
                DirectoryInfo d = new DirectoryInfo(filepath);
                foreach (var dwgfile in d.GetFiles("*.dwg", SearchOption.TopDirectoryOnly))
                    ed.WriteMessage("\nStart file: " + dwgfile.Name);
                    materialsCount = 0; // reset counter for new file
                    // Create a database
                    using (db)
                        try
                            db.ReadDwgFile(dwgfile.FullName, FileOpenMode.OpenForReadAndReadShare, true, null);    // open the dwg file
                            ObjectIdCollection ids = new ObjectIdCollection();
                            Transaction tr = db.TransactionManager.StartOpenCloseTransaction(); // should be faster than StartTransaction();
                            using (tr)
                                DBDictionary matDict = (DBDictionary)tr.GetObject(db.MaterialDictionaryId, OpenMode.ForRead, false);
                                foreach (DBDictionaryEntry entry in matDict)
                                    string key = entry.Key;
                                    if ((key != "ByBlock") && (key != "ByLayer") && (key != "Global"))
                                        ids.Add(entry.Value);
                                db.Purge(ids); // filters the list
                                foreach (ObjectId id in ids)
                                    DBObject obj = (DBObject)tr.GetObject(id, OpenMode.ForWrite);
                                    obj.Erase(); // purges the elements
                                    ++materialsCount;
                                tr.Commit();
                            }// end tr
                            ed.WriteMessage("\n" + materialsCount + " materials purged in: " + dwgfile.FullName);
                            db.SaveAs(dwgfile.FullName, true, DwgVersion.AC1024, null); // save as dwg2010
                        } //try
                        catch (System.Exception e)
                            ed.WriteMessage("\nUnable to process file:" + dwgfile.FullName);
                            ed.WriteMessage("\nException is: " + e.Message);
                    } // end db and close file
                } // end foreach
            } // end if
            else
                ed.WriteMessage("Invalid string input: " + pStrRes.Status.ToString());
        } //end method
Rambøll Danmark A/S
www.ramboll.dk
artc2
Perhaps MagiCAD's proxy graphics generation uses certain header variables or sysvars that are different between when the first dwg was saved to disk and the second was saved to disk.
mobj
Yes, that could be the case.
I'll try to get some information from MagiCAD.
Rambøll Danmark A/S
www.ramboll.dk
