Disappearing Tag - Local Model Cached Extents?
ACA 2012 VS2010
I have built an app where I am able to tag a strucural member. The tag displays as expected. I run into a problem when I later try to programatically change the StyleID of the tag. The tag then no longer displays. I can debug and find the handle of the tag. It appears the tag is there and that the style of the tag (multi-view block) has indeed changed. Once I run the Snoops app and selects the handle of the problem tag I notice that the Local Model cached Extents now displays as eInvalidExtents. So far this is the only difference I have found between a "good tag" and a "bad tag". Even though I am working with ACA I thought I would check to see if anyone had ideas on this issue.
Chris
