Disappearing Tag - Local Model Cached Extents?
ChrisPicklesimer
ChrisPicklesimer
ACA 2012 VS2010
I have built an app where I am able to tag a strucural member.  The tag displays as expected.  I run into a problem when I later try to programatically change the StyleID of the tag.  The tag then no longer displays.  I can debug and find the handle of the tag.  It appears the tag is there and that the style of the tag (multi-view block) has indeed changed.  Once I run the Snoops app and selects the handle of the problem tag I notice that the Local Model cached Extents now displays as eInvalidExtents.  So far this is the only difference I have found between a "good tag" and a "bad tag".  Even though I am working with ACA I thought I would check to see if anyone had ideas on this issue.
Chris
Virupaksha_aithal
Autodesk Support
Autodesk Support
Hi Chirs,
Sorry, I don't have an answer. I will suggest you try posting to ACA forum. I suspect majority of people visiting this forum are working with vanilla AutoCAD. There may be somebody over there who might be able to answer your question. (or cross post with pointers so that you get maximum exposure, at least.)
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
