Dimension value
Dimension value
Dimension value
I need in VB.NEt to copy the dimension text to a variable. I have a dimension that display "22" as value, but when I use the .measurement the value is "21.223233". There is a way to obtain the displaied value?
Paulio
I think you're looking for .DimensionText
thank you,
I tried DIMENSIONTEXT and work if I have a dimension with text override.
If the dimension text is not override the result is an empty string so I use the measurement but the result is not formatted as displaied.
Paulio
Oh I see. Your dimension style has a precision set for the primary units which is rounding the measurement.
I can't see anything that gives you the rounded figure. I guess you could get the number of decimal places from the .dimdec property then format the .measurement value to the same precision...
You can call the Dimension's FormatMeasurement() method and pass it the values
of the Measurement and DimensionText properties.
Thank you...I resolved it
Why not implement a function that read the exactly value displaied?
