dict.GetAt error return code?
Message 1 of 10
Can we test for a key in a dictionary without using the IDictionary
Enumerator and testing the whole dictionary. I was hoping for a retun
code similar to ARX eKeyNotFound when using dict.GetAt but this
just throws a system error when not found.
Thanks!
Replies (9)
Message 2 of 10
Here's what I'm using - actually very quick.
[code]
static public bool HasKey(DBDictionary dbDict, string dictKey)
foreach (DictionaryEntry de in dbDict)
if (de.Key.ToString() == dictKey)
return true;
return false;
[/code]
"Paul Richardson"
wrote in message
news:5683828@discussion.autodesk.com...
Thanks!
Message 3 of 10
How about this code
try
ObjectId id = dbDict.GetAt(dictKey);
return true;
catch
return false;
Message 4 of 10
I try to keep my trys for the unexpected but since it's an IDict it's
either this or the loop. Thanks.
wrote in message news:5684537@discussion.autodesk.com...
How about this code
try
return true;
catch
return false;
Message 5 of 10
Paul - What's wrong with the Contains() method ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
"Paul Richardson"
wrote in message news:5684696@discussion.autodesk.com...
How about this code
try
return true;
catch
return false;
Message 6 of 10
Nothing wrong with Contains() it's the coder...:) Thanks!
"Tony Tanzillo" wrote in message
news:5685719@discussion.autodesk.com...
"Paul Richardson"
wrote in message
How about this code
try
return true;
catch
return false;
Message 7 of 10
Just a point of clarification.
If you are testing to see if a key exists, and
if it does, retrieving the value, then don't use
Contains() followed by GetAt(), like this:
DBDictionary dict = // ...
if( dict.Contains("mykey") )
ObjectId id = dict.GetAt("mykey");
// use id
The reason this is not the preferred method, is
because it requires two lookups, rather than one.
Here is how I would do it:
DBDictionary dict = // ........
ObjectId id = ObjectId.Null;
try
catch {}
if( ! id.IsNull )
// use id here.
The reason I would take this approach is because
it allows me to get an existing value with only one
lookup rather than two (e.g., Contains() does one,
and GetAt() does another lookup).
Yes, it uses exception handling.
Yes, if your dictionary only has a handful of items
in it, it'll have no noticeable difference.
But, for the purpose of good, efficient coding and
scalable performance, in this case, using exception
handling allows you to get an existing value from
a dictionary with only one lookup, rather than two.
So, if someone has been preaching that without
condition, you should limit the use of use try/catch
to trapping unexpected errors, they're mistaken.
"Paul Richardson"
wrote in message news:5685742@discussion.autodesk.com...
"Paul Richardson"
wrote in message
How about this code
try
return true;
catch
return false;
Message 8 of 10
Thank you Tony - Nice explanation~
news:5685995@discussion.autodesk.com...
// use id
try
catch {}
if( ! id.IsNull )
// use id here.
"Paul Richardson"
wrote in message
"Paul Richardson"
wrote in message
How about this code
try
return true;
catch
return false;
Message 9 of 10
dgorsman
Thanks, Tony - I might be able to use this in a few other areas to clean up some machete-code I inherited.
Message 10 of 10
Oops. Sorry, that should have been:
try
catch {}
if( ! id.IsNull )
// use id here.
"Tony Tanzillo" wrote in message news:5685995@discussion.autodesk.com...
// use id
try
catch {}
if( ! id.IsNull )
// use id here.
"Paul Richardson"
"Paul Richardson"
wrote in message
How about this code
try
return true;
catch
return false;
