Detect if a drawing was OPENED?
rmduser
rmduser
Hi, there!
I have a specific problem regarding the DocumentCreated reactor, that is, I need to distinguish between a drawing being NEWLY CREATED or OPENED. Is there any indication for either case?
After a lot of trying and searching, I'm quite desparate by now 😞
Is there a sensible way for accomplishing this using DocumentCreated? Did I overlook any possibilities?
Thanks for any help!
Greetings,
AlfredG
I know if lisp we would look at the system variable 'dwgtitled'. If it
returned 0, then it is a new drawing.
Tim
"A blind man lets nothing block his vision."
wrote in message news:5516699@discussion.autodesk.com...
Hi, there!
Greetings,
AlfredG
If the OriginalFilename property of the Database
ends with .DWT or is an empty string, that should
indicate it is a new document.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
Hi, there!
Greetings,
AlfredG
You can use a dwg as a template, can not assume the ending to be "dwt" for
new drawings.
/Matt
"Tony Tanzillo" wrote in message
news:5516776@discussion.autodesk.com...
Hi, there!
Greetings,
AlfredG
Yea, but that doesn't matter if you use
this (even simpler) test:
bool IsNewDrawing(Document doc)
return doc.Name == doc.Database.Filename;
Only in a new, unsaved drawing should these
two properties have different values.
"Matt" wrote in message news:5517603@discussion.autodesk.com...
new drawings.
/Matt
Hi, there!
Greetings,
AlfredG
rmduser
Pretty cool: I was just thinking about the problem and came up with a similar idea myself, just seconds before getting notified about your last reply. In my case, I was trying to compare the "FileName" and "OriginalFileName" properties of the Database, which would NOT work.
However, YOUR suggestion seems to do the job!
Thanks a lot, you really saved my day! 🙂
Cheers,
Al
Oops, the == should be !=
public bool IsNewDrawing(Document doc)
return doc.Name != doc.Database.Filename;
"Tony Tanzillo" wrote in message news:5517635@discussion.autodesk.com...
new drawings.
/Matt
Hi, there!
Greetings,
AlfredG
