Design Automation
Design Automation
不适用
459 次查看
2 条回复
1 条消息(共 3 条)
Design Automation
不适用
What is the possibility of creating a tool that take two AutoCAD (DWG)  files as an input and produce an output depends on the order. For example  if i have the right of way (ROF) in a DWG file and the Land in another DWG file, would it be possible to send both files to a tool and order it to calculate the intersection area and produce a DWG file which shows where the intersection happens. Waiting for your kind help and advises. Thank you
0 个赞
460 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
hgasty1001
Please post example drawings with ROF, Land, and expected results, and any other information relevant to your problem. It's look doable. Just an idea: insert one drawing into the other (ROF into Land for example), and then calculate the intersection points between polylines.
Gaston Nunez
0 个赞
3 条消息(共 3 条)
dgorsman
As long as the procedure follows a logical process and has consistent data to draw from, then many things are possible.  Bad data + good math = bad results.  Good data + bad math = bad results.  Good results = good data + good math.
0 个赞
