Demand load from a server.
This may be a stupid question but I decided I should ask before I try to do
it. I've read about demand loading .NET dll's in the registry and I was
wondering if those dll's need to be on the local machine or if I can have
them sitting on a server somewhere? I'd much rather just replace a dll on a
server than having to distribute and installer to each individual.
Tim
You'd probably run into some .NET Security issues. you'd need to alter the security permissions on each machine that you intend to run the file on.
There is a command line tool for doing that, though, so it should be easy.
Something like "caspol.exe -machine -quiet -addgroup 1 -url file://MyServer/* FullTrust" should do it.
you can find caspol in c:\windows\microsoft.net\framework\version\
You'll have to check the syntax, I just got that from the 2.0 beta2 version, so it might different for 1.1. Message was edited by: Elscimar
