Deleting Wipeouts
Deleting Wipeouts
brianchapmandesign
Message 1 of 10
Deleting Wipeouts
brianchapmandesign
Is this correct?
namespace BCCDELWIPOUT
    public class DraftingTools
        [CommandMethod("BCC:WOUT")]
        public static void BCCDELETEWIPOUT()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                foreach (ObjectId objId in bt)
                    BlockTableRecord btr = objId.GetObject(OpenMode.ForRead) as BlockTableRecord;
                    foreach (ObjectId btrObjId in btr)
                        Entity ent = btrObjId.GetObject(OpenMode.ForRead) as Entity;
                        if (ent is Wipeout)
                            ent.UpgradeOpen();
                                ent.Erase();
            tr.Commit();
"Very funny, Scotty. Now beam down my clothes.
Replies (9)
Message 2 of 10
Hallex
No,
Wipeout is nothing but closed lwpolyline
with number of verices more than 3 items,
with every bulged segments,
so you can check all these properties to make
sure if you select wipeout
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 10
brianchapmandesign
Thanks again buddy!
Message 4 of 10
Alexander.Rivilis
Oleg! Are you sure??? Wipeout is Wipeout:
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 5 of 10
brianchapmandesign
Thanks Alexander.  Don't think this was always exposed to the API, correct? Might be why the suggestion.  I'm using 2012 Civil 3D... think it will work...
I just don't know the right way to collect the Wipeouts... as you can see in my code...  I'm doing something wrong but not sure what.  One thing is I don't think I have to ent.UpgradeOpen, I think I can just ent.erase but I'm crashing so there must be something else wrong.
Message 6 of 10
Alexander.Rivilis
@bcinnv wrote:
...Don't think this was always exposed to the API, correct?...
IMHO class Wipeout is exposed with AutoCAD .NET API since AutoCAD 2008.
Try replace code:
using (tr)
tr.Commit();
with:
using (tr)
     tr.Commit();
Expert Elite Member
Message 7 of 10
Hallex
I knew that thanks
But why this way it's not working this way?
(ssget "_X" '(( 0 . "wipeout")))
Message 8 of 10
brianchapmandesign
Thanks Alexander you were correct! The placement of the TR was the problem.  Updated code below:
// delete wipeouts
            using (tr)
                BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForWrite) as BlockTable;
                    BlockTableRecord btr = objId.GetObject(OpenMode.ForWrite) as BlockTableRecord;
                        Entity ent = btrObjId.GetObject(OpenMode.ForWrite) as Entity;
                        if (ent is Wipeout)
                            ent.Erase();
                } tr.Commit();
Message 9 of 10
brianchapmandesign
Thanks! That was the way I did it in Lisp. I have decided to convert 10 years of lisp routines I've collected / created into C#, somewhat to learn, but also because I like the better performance with .net.  There is such little material about C# out there than there was .lsp it's considerably harder, but always enjoy a challenge 🙂
Thanks for the help Hallex! Always appreciated.
Message 10 of 10
swaywood
now i am doing the same work , convert 10-years of lisp to c#.
