Delete Block Attributes
seabrahenrique
seabrahenrique
Hello Guys,
I've been try to write a code that simple remove all attributes of a block, and then i'll put new ones.
To do that, i tried to clean the AttDefinitions of BlockTableRecord, and then synchronize the attributes like that:
        [CommandMethod("CleanAttsDef")]
        public static void CleanAttsDef()
            Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor edt = doc.Editor;
            PromptEntityOptions promptEntity = new PromptEntityOptions("Selecione o bloco para limpar os atributos");
            PromptEntityResult result = edt.GetEntity(promptEntity);
            if (result.Status == PromptStatus.OK)
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    Entity ent = tr.GetObject(result.ObjectId, OpenMode.ForWrite) as Entity;
                    edt.WriteMessage(ent.GetType().ToString());
                    if (ent is BlockReference br)
                        BlockTableRecord btr = tr.GetObject(br.BlockTableRecord, OpenMode.ForWrite) as BlockTableRecord;
                        foreach (ObjectId objID in btr)
                            Entity internalEnty = tr.GetObject(objID, OpenMode.ForWrite) as Entity;
                            if (internalEnty is AttributeDefinition attDef)
                                attDef.Erase();
                        tr.Commit();
                    BlockReference br = tr.GetObject(result.ObjectId, OpenMode.ForWrite) as BlockReference;
                    btr.SynchronizeAttributes();
                    tr.Commit();
Note that i used the extension method of that post to do the Synchronize.
The code works perfect, except for one detail: after i run it, the block stay in a state that always i try to do something with they (for example change the scale factors) i face that message bellow:
Actually, i was ignoring that problem... but i started to face other problems related with that...
Mysteriously, when i close and open the drawing the message desapear... and also if i deleted the AttDefinition and use the AutoCAD command "ATTSYNC" i also can "solve" the problem...
Even so, I'm looking for a more "solid" solution using .NET itself...
Thanks in advance.
_gile
Thanks for reporting.
I seems there's an issue after erasing attribute references from the attribute collection.
The AttributeCollection.Count returns 0 but it still contains the ObjectId of one erased attribute reference.
Try this code:
[CommandMethod("TEST")]
public void Test()
    var doc = Application.DocumentManager.MdiActiveDocument;
    var db = doc.Database;
    var ed = doc.Editor;
    var options = new PromptEntityOptions("\nSelect block reference: ");
    options.SetRejectMessage("\nSelected object is not a block reference.");
    options.AddAllowedClass(typeof(BlockReference), true);
    var result = ed.GetEntity(options);
    if (result.Status != PromptStatus.OK) return;
    using (var tr = db.TransactionManager.StartTransaction())
        var br = (BlockReference)tr.GetObject(result.ObjectId, OpenMode.ForRead);
        var btr = (BlockTableRecord)tr.GetObject(br.BlockTableRecord, OpenMode.ForWrite);
        foreach (ObjectId id in btr)
            if (id.ObjectClass.Name == "AcDbAttributeDefinition")
                var attRef = (AttributeDefinition)tr.GetObject(id, OpenMode.ForWrite);
                attRef.Erase();
        // Check the AttributeCollection
        ed.WriteMessage($"\nNumber of attribute references = {br.AttributeCollection.Count}");
        foreach (ObjectId id in br.AttributeCollection)
            ed.WriteMessage($"\nAttribute reference {id} IsErased = {id.IsErased}");
        tr.Commit();
I haven't yet found a way to solve this problem.
Gilles Chanteau
GileCAD
GitHub
_gile
This seems to be an old bug: http://www.theswamp.org/index.php?topic=41945
Gilles Chanteau
GileCAD
GitHub
seabrahenrique
Thanks! That help for now.
denisyukJ
Hello, @_gile
I coudn't find SynchronizeAttributes() method in BlockTableRecord class. ACAD 24.
BR,
Evgeniy
_gile
@denisyukJ
SynchronizeAttributes is an extension method I wrote.
The link provided by @seabrahenrique points to a topic that have been archived erased by Autodesk.
You can find a version of the SynchronizeAttributes extension method in the Gile.AutoCAD.Extension library.
Gilles Chanteau
GileCAD
GitHub
denisyukJ
@_gile, thank you!
