Debugging AutoCAD 2008 with Visual Studio 2010 Express
I have read various forum posts and seen different google responses. Is it possible to debug a .net project in AutoCAD 2008 with Visual Studio 2010?
I have modified the acad.exe.config file as shown below:
<configuration>
   <startup>
        <supportedRuntime version="v2.0.50727"/>
   </startup>
</configuration>
And I have set the visual studio debug options to:
Command Line Arguments: start acad.exe
Working Directory: C:\Program Files\AutoCAD Architecture 2008\
Enable the Visual Studio Hosting Process: Checked
I build the project, then i try to start debugging. I get the following error:
System.Reflection.ReflectionTypeLoadException was unhandled
  Message=Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
  Source=mscorlib
Any help would be much appreciated. Thanks in advance.
I use option 3 as recommended in this article. From through-the-interface
Works fine for me.
ed. - Actually, I'm not using Express so I don't know if that option will work for you.
Perhaps someone else can tell me otherwise, but option 3 doesn't work for me because VS2010 Express doesn't let me add an exe as an existing project.
I found the solution for C# here:http://forums.autodesk.com/t5/NET/Visual-C-Express-2010/m-p/2886742#M22282
This fix also works for vb.net, just modify the .vbproj instead of .csproj.
