DBMOD Systemvariable Changed event??
Hi there,
I'm trying to retrieve the DBMOD system variable change...
No luck however.
I retrieve the variable with:
Application.GetSystemVariable("DBMOD")
But after retrieval (when a document has become active) i want my application to know if a document was changed. So the user can see what documents need saving (Tabs on a Palette)
I Tried a Handler to the SystemVariableChanged event of the Application, but it doesn't contain or raises the event (I do see that events are raised, so the event works.)
Does anybody know where (and if) the DBMOD variable is raised as a event if changed?
Or maybe how to see if the document was changed (maybe use the "ObjectModified" event of the database?, and reset a variable on a save....??
ps. The database systemvariablechanged doesn't raise it either!
Not all system variables are supported by the event.
Why not just check the value in the handler of an event that fires routinely, and if non-zero, then act?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5856932@discussion.autodesk.com...
Hi there,
No luck however.
I have a declaration of the variable in a module and a public sub that I call at the end of my routines that updates the status bar of my form, it's simple and harmless. In particular tools I have implemented also the other values of "dbmod", but it was specific for certain applications.
Friend myDBMOD As Integer 'Current Drawing Saved Status
'0=Drawing Saved 1=Object database modified 4=Database variable modified
'8=Window modified 16=View modified 32=Field modified
Sub UpdDwgStatus()
myDBMOD = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("dbmod")
With frmMain.GTA_StripStatusFile
' frmMain.GTA_StripStatusFile is the StatusStripControl
Dim f As New System.Drawing.Font("Tahoma", 8.25)
.Font = f
If myDBMOD = 0 Then
.Text = "Saved"
.ForeColor = Drawing.Color.Green
.Font = New System.Drawing.Font(.Font, Drawing.FontStyle.Regular)
Else
.Text = "Not Saved"
.ForeColor = Drawing.Color.Red
.Font = New System.Drawing.Font(.Font, Drawing.FontStyle.Bold)
End If
End With
End Sub ' Updates StatusBar with Current Drawing Status
Sorry for the formatting, I just did a copy/past and added a few comments.
René
Thanks Tony,
- I'll guess for now I'll set the property IsChanged of my custom per-document class to True if a ObjectModified event happens.
- on creation of the document I'll retrieve the DBMOD
- If as "Save" command ends I'll re-check the DBMOD variable, if 0 I'll set the IsChanged to false.
A Caddie.
