Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Database.ObjectAppended differences between 2010 to 2012
BrentBurgess1980
BrentBurgess1980
I have been playing around with a some samples from DevTV, and have come across something strange.
This snippet produces 2 different results between 2010 and 2010 when I draw a single line.
  Private Sub callback_ObjectAppended(ByVal sender As Object, ByVal e As ObjectEventArgs)
    ' add the class name of the object to the tree view
    Dim newNode As System.Windows.Forms.TreeNode = myPalette.TreeView1.Nodes.Add(e.DBObject.GetType().ToString())
    ' we need to record its id for recognition later
    newNode.Tag = e.DBObject.ObjectId.ToString()
  End Sub
 The attached image shows the difference. The palette on the right is from 2010, and on the left 2012.
Has there been a change in the Database.ObjectAppended Event between 2010 and 2012? Is there a way to only show the visible entity created in the treeview?
Brent
I have noticed that but it was only when the first objected was added.(The Little bit I tested)
Will you do me a favor and add a dimension and see what the difference is? (Does not have to be the first object)
http://www.theswamp.org/index.php?topic=38440.msg435534#msg435534
BrentBurgess1980
I have just left, but will try it out on Tuesday and let you know
