database free the memory
Message 1 of 14
how to  free the memory  with ReclaimMemoryFromErasedObjects ?   I try to  load file  then    delete all objects  ,  But  I find  the memoey  increase more and more?  what's wrong?
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.Gis.Map.Platform.Utils;
namespace ReclaimMemory
    public class Class1
        [CommandMethod("hello")]
        public void hello()
            Util.PrintLn("com to  hello");
        [CommandMethod("MyMemory")]
        public void myMemory()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Database destDb = Application.DocumentManager.MdiActiveDocument.Database;
            for (int i = 0; i < 50; i++)
                string filename = "C:\\110344.dwg";
                Util.PrintLn("file"+i);
                Database sourceDb = new Database(false, true);
                sourceDb.ReadDwgFile(filename, System.IO.FileShare.Read, false, null);
                var SourceObjectIds = new ObjectIdCollection();
                Autodesk.AutoCAD.DatabaseServices.TransactionManager SourceTm = sourceDb.TransactionManager;
                using (Transaction trans = destDb.TransactionManager.StartTransaction())
                    try
                        var blockTable = (BlockTable)trans.GetObject(destDb.BlockTableId, OpenMode.ForRead);
                        using (Transaction extTrans = sourceDb.TransactionManager.StartTransaction())
                            dynamic extBlockTable = (BlockTable)extTrans.GetObject(sourceDb.BlockTableId, OpenMode.ForRead);
                            dynamic extModelSpace = (BlockTableRecord)extTrans.GetObject(extBlockTable[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                            foreach (ObjectId id in extModelSpace)
                                SourceObjectIds.Add(id);
                        sourceDb.CloseInput(true);
                        dynamic idmapping = new IdMapping();
                        // destDb.WblockCloneObjects(SourceObjectIds, destDb.BlockTableId, idmapping, DuplicateRecordCloning.Replace, false);
                        destDb.WblockCloneObjects(SourceObjectIds, blockTable[BlockTableRecord.ModelSpace], idmapping, DuplicateRecordCloning.Ignore, false);
                        trans.Commit();
                    catch (System.Exception ex)
                        Util.PrintLn(ex.Message);
                string saveFile ="C:\\"+ i + ".dwg";
                destDb.SaveAs(saveFile, true, DwgVersion.AC1800, null);
                //**************delete objects  and  free  memory
                using (ObjectIdCollection erased = new ObjectIdCollection())
                        BlockTable bt = (BlockTable)trans.GetObject(destDb.BlockTableId, OpenMode.ForWrite);
                        foreach (ObjectId btrid in bt)
                            BlockTableRecord btr = (BlockTableRecord)trans.GetObject(btrid, OpenMode.ForWrite);
                            foreach (ObjectId eid in btr)
                                Entity ent = trans.GetObject(eid, OpenMode.ForWrite) as Entity;
                                if (ent != null)
                                    ent.Erase(true);
                                    erased.Add(eid);
                        trans.Commit();
                    destDb.ReclaimMemoryFromErasedObjects(erased);
                    erased.Clear();
Replies (13)
Message 2 of 14
ActivistInvestor
It's hard to tell what's wrong without testing your code, but I would suggest reading the native API docs for reclaimMemoryFromErasedObjects(), because it goes into much greater detail than the managed API docs.
Message 3 of 14
i find  the memory  begin to be  free , when  all  the  50 files work finish...
i  want  to  that  when  one  file  finish work ,the memory  begin  to free  immediately,so  the  max  memory  overhead is  not so large
so  the   "ReclaimMemoryFromErasedObjects"  is not  usefull  for  me ?
Message 4 of 14
_gile
Just a shoot in the dark, not tested with a big amount of files.
What if you call Dispose() on the newly created Database, or, better wrap int in a using statement:
using(Database sourceDb = new Database(false, true))
// use sourceDb
} // sourceDb is disposed here and can be garbage collected
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 5 of 14
i  change  code like this
using System;
using System.Linq;
using System.Text;
    public class Class1
        public void hello()
                    try
                        trans.Commit();
//**************add dispose()
sourceDb.Dispose();
SourceObjectIds.Dispose(); } catch (System.Exception ex) { Util.PrintLn(ex.Message); } } string saveFile ="C:\\"+ i + ".dwg"; destDb.SaveAs(saveFile, true, DwgVersion.AC1800, null); //**************delete objects and free memory using (ObjectIdCollection erased = new ObjectIdCollection()) { using (Transaction trans = destDb.TransactionManager.StartTransaction()) { BlockTable bt = (BlockTable)trans.GetObject(destDb.BlockTableId, OpenMode.ForWrite); foreach (ObjectId btrid in bt) { BlockTableRecord btr = (BlockTableRecord)trans.GetObject(btrid, OpenMode.ForWrite); foreach (ObjectId eid in btr) { Entity ent = trans.GetObject(eid, OpenMode.ForWrite) as Entity; if (ent != null) { ent.Erase(true); erased.Add(eid); } } } trans.Commit(); } destDb.ReclaimMemoryFromErasedObjects(erased);
//********* add dispose()
destDb.Dispose();
erased.Clear();
  dispose  function  seem  to be unuseful  .
  the file  of "C:\\110334.dwg"  is  1.9MB , in the  working  processing , The most  memory overhead  of acad.exe   is more than  3G !
 when all  the work  finish ,  the acad.exe  memory  overhead  reduce to about  900M
Message 6 of 14
_gile
Looking more attentively to your code, it seems to me it needs some algorithmic and coding optimisation.
You do not need to create 50 side databases to get get everytime the same ObjectIdCollection.
You should create 50 side databases to create the new dwg files.
You should not use the dynamic type for strongly typed objects (use the type or var keyword instead).
Try something like this.
            // Get the source ObjectIds from sourceDb only once
            var sourceObjectIds = new ObjectIdCollection();
            using (Database sourceDb = new Database(false, true))
                sourceDb.ReadDwgFile(filename, FileOpenMode.OpenForReadAndAllShare, false, null);
                using (Transaction extTrans = sourceDb.TransactionManager.StartOpenCloseTransaction())
                    var extBlockTable = (BlockTable)extTrans.GetObject(sourceDb.BlockTableId, OpenMode.ForRead);
                    var extModelSpace = (BlockTableRecord)extTrans.GetObject(extBlockTable[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                        sourceObjectIds.Add(id);
                // Loop to create the 50 new files
                    Util.PrintLn("file" + i);
                    string saveFile = "C:\\" + i + ".dwg";
                    using (var destDb = new Database(true, true))
                        var mapping = new IdMapping();
                        sourceDb.WblockCloneObjects(
                            sourceObjectIds,
                            SymbolUtilityServices.GetBlockModelSpaceId(destDb),
                            mapping,
                            false);
Gilles Chanteau
GileCAD
GitHub
Message 7 of 14
thank  you for reply!
oh~~~~ as  your code ,maybe  much better.
Actually, very time  the  file  loaded   is different,  it  just  a  test , so  i  get  the  same  file
Actually,I have more  than 50 different  files ,then  operate the  file  ,then  save  and  close, one by one
can you understand  what i mean?
Message 8 of 14
_gile
Sorry I cannot understand what you're trying to do.
The code I purposed is an optimisation of the one you posted (creating 50 new files with the content of the sourceDB model space). If this does not reflect what you're trying to achieve, why do you use it as testing code ?
So please, just try to clearly explain what you want you to so that we're not shooting in the dark...
Gilles Chanteau
GileCAD
GitHub
Message 9 of 14
i am sorry ,  My  English  is poor
the  actual   code    like  this
using System.Linq; using System.Text; using System.Threading.Tasks; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; using Autodesk.Gis.Map.Platform.Utils; namespace ReclaimMemory { public class Class1 { [CommandMethod("hello")] public void hello() { Util.PrintLn("com to hello"); } [CommandMethod("MyMemory")] public void myMemory() { Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument; Database destDb = Application.DocumentManager.MdiActiveDocument.Database; for (int i = 0; i < 50; i++) { //string filename = "C:\\110344.dwg"; string filename = "C:\\110344"+i+".dwg"; Util.PrintLn("file"+i); Database sourceDb = new Database(false, true); sourceDb.ReadDwgFile(filename, System.IO.FileShare.Read, false, null); var SourceObjectIds = new ObjectIdCollection(); Autodesk.AutoCAD.DatabaseServices.TransactionManager SourceTm = sourceDb.TransactionManager; using (Transaction trans = destDb.TransactionManager.StartTransaction()) { try { var blockTable = (BlockTable)trans.GetObject(destDb.BlockTableId, OpenMode.ForRead); using (Transaction extTrans = sourceDb.TransactionManager.StartTransaction()) { dynamic extBlockTable = (BlockTable)extTrans.GetObject(sourceDb.BlockTableId, OpenMode.ForRead); dynamic extModelSpace = (BlockTableRecord)extTrans.GetObject(extBlockTable[BlockTableRecord.ModelSpace], OpenMode.ForRead); foreach (ObjectId id in extModelSpace) { SourceObjectIds.Add(id); } } sourceDb.CloseInput(true); dynamic idmapping = new IdMapping(); // destDb.WblockCloneObjects(SourceObjectIds, destDb.BlockTableId, idmapping, DuplicateRecordCloning.Replace, false); destDb.WblockCloneObjects(SourceObjectIds, blockTable[BlockTableRecord.ModelSpace], idmapping, DuplicateRecordCloning.Ignore, false); trans.Commit(); } catch (System.Exception ex) { Util.PrintLn(ex.Message); } } string saveFile ="C:\\"+ i + ".dwg"; destDb.SaveAs(saveFile, true, DwgVersion.AC1800, null); //**************delete objects and free memory using (ObjectIdCollection erased = new ObjectIdCollection()) { using (Transaction trans = destDb.TransactionManager.StartTransaction()) { BlockTable bt = (BlockTable)trans.GetObject(destDb.BlockTableId, OpenMode.ForWrite); foreach (ObjectId btrid in bt) { BlockTableRecord btr = (BlockTableRecord)trans.GetObject(btrid, OpenMode.ForWrite); foreach (ObjectId eid in btr) { Entity ent = trans.GetObject(eid, OpenMode.ForWrite) as Entity; if (ent != null) { ent.Erase(true); erased.Add(eid); } } } trans.Commit(); } destDb.ReclaimMemoryFromErasedObjects(erased); erased.Clear(); } } } } }
 i  change  the code  "string   filename="C:\\110334.dwg""   to   "string  filename="c:\\110334"+i+".dwg""
every time  ,I  load  the  different  file
Message 10 of 14
Juergen_Becker
please commit all your transaction even if it is not really necessary.
Look here: http://spiderinnet1.typepad.com/blog/2012/01/autocad-net-transaction-and-performance.html
When you commit it is much faster and saver.
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
Message 11 of 14
_gile
Your code remains confusing (you call WblockCloneObjects on the destination database instance whith object ids from the source database).
If I don't misundertand, you already have 50 source files on C: drive (1103440.dwg, 1103441.dwg, ..., 11034449.dwg) and you to create 50 new files on C: (0.dwg, 1.dwg, ..., 49.dwg) and copying the contents of the source file model space into the new file.
If this is not what you want to achieve, please explain what you're trying to do in plain English (use Google transalation if needed) without showing code which does not reflect your goal.
If I completely understood, it looks like copying files and you can simply copy the files without using AutoCAD:
    System.IO.File.Copy("C:\\110344" + i + ".dwg", "C:\\" + i + ".dwg");
If you absolutely need to make a Wbloc operation (i.e. do not copy the layouts), try the following code and overall compare it to your code to try to understand what was wrong with yours:
                string filename = "C:\\110344" + i + ".dwg";
                // get the ObjectIds form sourceDb model space
                    // create a new file and copy the objects
                            sourceObjectIds,
                            mapping,
                            false);
Gilles Chanteau
GileCAD
GitHub
Message 12 of 14
_gile
With your code (your algorithm more accurately), the memory increase because you add entities to the current database and erase them at each iteration. AutoCAD keeps all these operations in memory.
The code I purposed creates each new drawing "in memory" as side database and does nothing to the current database.
Gilles Chanteau
GileCAD
GitHub
Message 13 of 14
greate  !   you are right!
that's  the code  i want  ,thank   you  very much!
Besides ,I  have a  another  quesion
you said  that " ......a Wbloc operation (i.e. do not copy the layouts)",
I absolutely need to make a Wbloc operation,  want  copy  everything  from  source  fiel  ,contain   layouts..   what  should  i do ?
Message 14 of 14
_gile
As I said upper, if you simply want to copy the whole files, you do not need to use AutoCAD.
Just create a simple Console Application with:
    class Program
        static void Main(string[] args)
Gilles Chanteau
GileCAD
GitHub
