- Mark as New
 - Bookmark
 - Subscribe
 - Mute
 - Subscribe to RSS Feed
 - Permalink
 - Report
here is my code
public static class Active
    public static Document Document
        get { return Application.DocumentManager.MdiActiveDocument; }
    public static Database Database
        get { return Document.Database; }
    public static string Name
        get { return Database.Filename; }
}Active.Name some return the autosave filename, e.g.
C:\Documents and Settings\Davisas\local settings\temp\TDB0157-006A-FP00_1_1_1030.sv$
the correct one should be
C:\Documents and Settings\Davisas\local settings\temp\TDB0157-006A-FP00.dwg
Is this a bug? how to avoid it?
Thank you so much.
Wes
	Windows 10 64 bit, AutoCAD (ACA, Map) 2023
