custom Treeview
custom Treeview
Message 1 of 16
custom Treeview
Hi i am totally new here. can anybody be kind to guide me into creating a custom treeview in AutoCAD 2010 using Visual studio 2008 with C#? i have no idea how to start. all i have known is i just gone through some tutorial about creating a helloworld command in autocad 2010 and something like that.. thanks.
Replies (15)
Message 2 of 16
http://msdn.microsoft.com/en-us/beginner/default.aspx
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6289377@discussion.autodesk.com...
that.. thanks.
Message 3 of 16
I would start here:
that.. thanks.
Message 4 of 16
Hallex
Here is a quick windows application partially borrowed from
my custom lisp navigator
Hope this helps
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 5 of 16
Tony, i have got to ask - is this where you got your start (LOL)
Patrick Johnson
http:\\www.cadenhancement.com
Message 6 of 16
Hi Tony thanks for the reply.. i have go through the site, but i have to ask, is there any API thing, that i can build a treeview in AutoCAD 2010 instead of building a windows application of treeview? thanks
Message 7 of 16
Thanks hallex
Message 8 of 16
The way you use a treeview in AutoCAD isn't much different from the way you
do it in a windows application.
But, to do that, you have to be reasonably familar building AutoCAD
applications using .NET, and it's fairly obvious from your questions that
you've never done that before.
Using .NET and AutoCAD's ObjectARX API is something that requires some
learning and experience, which is why I pointed you at that site.
It seems that you're looking for an 'easy button'. Sorry to disappoint, but
there is none.
wrote in message news:6292455@discussion.autodesk.com...
Message 9 of 16
Hallex
You're welcome
Cheers 🙂
~'J'~
Message 10 of 16
Thanks, i was just confused because i am suppose to make a treeview in AutoCAD, but seems that the web you suggested somehow guided me into a windows application.. thanks for the explanation..
Message 11 of 16
That site was more about learning to use the tools, which
are the same whether you are developing standalone windows
applications or AutoCAD appilicatons.
wrote in message news:6292611@discussion.autodesk.com...
Message 12 of 16
ok.. may i have any clue about which dll class in autoCAD should i make reference to?? for the treeview i mean.. thanks
Message 13 of 16
The treeview is NOT part of the acad API. It is part of the Windows framework.
You may use it when you create a dialog box in autocad, then populate it with the autocad data that you wish
Patrick Johnson
Message 14 of 16
thanks for the info Patrick. may i know where can i learn all these creating a dialog box?? i have learnt how to make a very simple tree view and adding nodes into it. do i need to compile it into an exe file or something like that in order for it to work in AutoCAD?
Message 15 of 16
It sounds that you are very new to programming in general and here is what you need to do besides maybe going to where Tony sent you
Get SDK on autocad API and do tutorials
Get a couple reference books on dot net programming
You may want to take some classes on programming
If you are working for a company - hire it out
Just my .02 cents worth
Patrick Johnson
Message 16 of 16
I am still a student.. this is my homework.. this is kind of new to me.. all i know is C and C++ programming.. i never deal with C# and windows form type programming.. thanks for the guides..
