Custom palette set docking issue
hierholzer
Message 1 of 1
hierholzer
Hello everyone,
I have a custom palette set, which I want to dock at the left side of AutoCAD. If there is already docked a palette set window, e. g. the object properties, it will be displayed above the already docked one at first start. See the following screenshot as an example:
First start of custom palette setFirst start of custom palette set
If there is no pallete set window docked it displays as expected:
When I now close my custom palette set, dock the properties window back on the left side and open my palette set again it docks the way I also would expect for the first start:
Here is my code for the custom palette set:
public class DockingWindow : PaletteSet
      private Control userControl;
      public DockingWindow(Control userControl, Guid classId, string caption, DockSides dockSide, DockSides dockEnabled) : base(caption, classId)
         this.userControl = userControl;
         this.Style = PaletteSetStyles.ShowPropertiesMenu | PaletteSetStyles.ShowAutoHideButton | PaletteSetStyles.ShowCloseButton;
         this.DockEnabled = dockEnabled;
         this.Name = caption;
         this.Add(caption, this.userControl);
         this.Size = new Size(userControl.Width, userControl.Height);
         this.MinimumSize = userControl.MinimumSize;
         this.Visible = true;
         this.Dock = dockSide;
DockingWindow dockingWindow;
Guid guid = Guid.Empty;
[CommandMethod("CreateDockingWindow")]
public void CreateDockingWindow()
         if (this.dockingWindow == null)
            UCTest ucTest = new UCTest();
            guid = ucTest.GetType().GUID;
            dockingWindow = new DockingWindow(ucTest, guid, "Test", DockSides.Left, (DockSides)(DockSides.Left | DockSides.Right));
         else
            this.dockingWindow.Visible = true;
Is there a way to dock my custom window next to already docked windows at first start and not above?
Thank you in advance.
Best regards,
Alex
Replies (0)
