Custom implementation of select similar
Can any one guide how to implement select similar functionality using .net interface.
Issue facing: Am trying to get all the entities in drawing by block reference name ..But only one element is coming as result set ..But if right click and use select similar command all the similar block references are getting selected.
I am clueless what am i missing in this case?
_gile
Here's a little example:
        [CommandMethod("SELECTBLOCKBYNAME")]
        public static void SelectBlockByName()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var peo = new PromptEntityOptions("\nSelect a block: ");
            peo.SetRejectMessage("\nselected object is not a block reference.");
            peo.AddAllowedClass(typeof(BlockReference), true);
            var per = ed.GetEntity(peo);
            if (per.Status == PromptStatus.OK)
                ObjectId[] ids;
                using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                    string GetEffectiveName(BlockReference br) =>
                        br.IsDynamicBlock ?
                        ((BlockTableRecord)tr.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead)).Name :
                        br.Name;
                    var source = (BlockReference)tr.GetObject(per.ObjectId, OpenMode.ForRead);
                    var name = GetEffectiveName(source);
                    ids = ((BlockTableRecord)tr.GetObject(source.OwnerId, OpenMode.ForRead))
                        .Cast<ObjectId>()
                        .Where(id => id.ObjectClass.DxfName == "INSERT")
                        .Select(id => (BlockReference)tr.GetObject(id, OpenMode.ForRead))
                        .Where(br => GetEffectiveName(br) == name)
                        .Select(br => br.ObjectId)
                        .ToArray();
                ed.SetImpliedSelection(ids);
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Hi @_gile
Thanks for the instant reply. But how to change this particular code
                        .Cast<ObjectId>()
                        .ToArray();
 In  the above code snippet
                        .Cast<ObjectId>()
How to avoid the above if i have only block name and not prompting
user to select a type from the user interface
 Previously was using a function like this
static private ObjectIdCollection GetAllBlockReferenceByName(string name, Database db)
ObjectIdCollection ids_temp = null, ids = new ObjectIdCollection();
Transaction tr = db.TransactionManager.StartTransaction();
try
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[name], OpenMode.ForRead);
BlockTableRecord btr_model = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
ObjectId id_model = btr_model.ObjectId;
ids_temp = btr.GetBlockReferenceIds(true, true);
foreach (ObjectId id in ids_temp)
DBObject obj = (DBObject)tr.GetObject(id, OpenMode.ForWrite);
if (obj.OwnerId == id_model)
ids.Add(id);
tr.Commit();
finally
tr.Dispose();
return ids;
_gile
Assuming the block is not a dynamic block, you can try this:
        private static ObjectId[] GetAllBlockReferenceByName(string name, Database db)
                var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                if (!bt.Has(name))
                    return null;
                var msId = SymbolUtilityServices.GetBlockModelSpaceId(db);
                var btr = (BlockTableRecord)tr.GetObject(bt[name], OpenMode.ForRead);
                return btr.GetBlockReferenceIds(true, true)
                    .Cast<ObjectId>()
                    .Where(id => tr.GetObject(id, OpenMode.ForRead).OwnerId == msId)
                    .ToArray();
Testing command:
        [CommandMethod("TEST")]
        public static void Test()
            var pr = ed.GetString("\nBlock Name: ");
            if (pr.Status != PromptStatus.OK)
                return;
            var ids = GetAllBlockReferenceByName(pr.StringResult, db);
            if (ids == null)
                ed.WriteMessage($"\nBloc '{pr.StringResult}' not found.");
            else
Gilles Chanteau
GileCAD
GitHub
_gile
This one will also work with dynamic blocks
                if (!bt.Has(name))
                    return null;
                    .Cast<ObjectId>()
                    .Concat(btr.GetAnonymousBlockIds()
                            .Cast<ObjectId>()
                            .SelectMany(anonId => ((BlockTableRecord)tr.GetObject(anonId, OpenMode.ForRead))
                                                    .Cast<ObjectId>()))
                    .ToArray();
Gilles Chanteau
GileCAD
GitHub
