CUI Combobox
CUI Combobox
waseefur.rahman
Message 1 of 10
CUI Combobox
waseefur.rahman
Hi all,
I have been Trying to Create a CUI Combobox, through .net and if User Select any Item in Combobox, then I should call my sub to do some operations,
I have created a CUI Combobox through Partial Customization file , but I don't know how to add my own item in that combobox and if any item is selected then I need to call my sub, also I have attached a image,
can anyone guide me how to achieve it.
Thanks in Advance...
Replies (9)
Message 2 of 10
moogalm
Autodesk Support
Autodesk Support
The layercontrol in the image is a ToolbarControl added to CUI Toolbar, these are predefined controls you can only add them to a toolbar.
I don't think you can edit the control.
Can you please let me know what is your objective ?
like layercontrol, you can create new ToolbarControl based on control types.
public enum ControlType
       LayerControl = 1,
       LineTypeControl = 2,
       OPTColorControl = 3,
       LineWeightControl = 4,
       RefblknameControl = 5,
       ArrayEditNameControl = 6,
       ViewportScaleControl = 7,
       ViewControl = 8,
       PlotStyleControl = 9,
       UCSControl = 10,
       DimStyleControl = 11,
       UndoSkinnyButtonControl = 12,
       RedoSkinnyButtonControl = 13,
       TxtStyleControl = 14,
       TblStyleControl = 15,
       NamedViewControl = 16,
       WorkspacesControl = 17,
       MldStyleControl = 18,
       FindTextControl = 19,
       ContentSearchControl = 20,
       CustomControl = 21,
       _3DNavViewComboCtrl = 5000,
       _3DNavZoomSliderControl = 5001,
       _3DNavStepSizeSliderControl = 5002,
       _3DNavStepsPerSecSliderControl = 5003,
       _3DNavPointTriplet1 = 5004,
       _3DNavPointTriplet2 = 5005,
       LightSliderControl1 = 5006,
       LightSliderControl2 = 5007,
       LightSliderControl3 = 5008,
       LightSliderControl4 = 5009,
       LightSliderControl5 = 5010,
       LightColorCorrectCtrl = 5011,
       RenderStyleControl = 5012,
       RenderProgressControl = 5013,
       RenderImageQualityControl = 5014,
       RenderOutputFileControl = 5015,
       RenderOutputSizeControl = 5016,
       VSStylesComboControl = 5017,
       VSEdgeColorControl = 5018,
       VSEdgeOverhangSliderControl = 5019,
       VSJitterEdgeSliderControl = 5020,
       VSSilhouetteEdgeWidthSliderControl = 5021,
       VSObscuredEdgeColorControl = 5022,
       VSIntersectionEdgeColorControl = 5023,
       LayerStateComboControl = 5024,
       LayerLockTransparencySliderControl = 5025,
       LayerFilterComboControl = 5026,
       TextHeightComboControl = 5027
Message 3 of 10
moogalm
Autodesk Support
Autodesk Support
        LayerControl = 1,
        ViewControl = 8,
        UCSControl = 10,
        CustomControl = 21,
Message 4 of 10
waseefur.rahman
Hi Madhukar,
I don't want to edit layertype Combobox, or even i don't need any predefined Combobox,
just for example I have shown that in image.
I want to create a New Combobox in toolbar, in that Combobox items will be added from the database &
if user select any item, I want to run my sub.
Message 5 of 10
moogalm
Autodesk Support
Autodesk Support
At the moment API facilitate only to create ToolbarControl of predefined type.
Sorry about that 😞
Message 6 of 10
Juergen_Becker
just a try. Maybe it works.
Please insert following references first: AcWindows.dll, AdWindows.dll and following using.
using Autodesk.Windows;
RibbonCombo m_RibbonCombo = new RibbonCombo();
m_RibbonCombo.Items.Add(new object());
m_RibbonCombo.CurrentChanged += M_RibbonCombo_CurrentChanged;
The object can be any object for example a Person. One Point is important: Override the method ToString() with that what you want to see in the Combobox.
Handle the CurrentChanged evant like this:
Version:1.0 StartHTML:00000138 EndHTML:00000901 StartFragment:00000242 EndFragment:00000869 StartSelection:00000242 EndSelection:00000869Snippet
private static void M_RibbonCombo_CurrentChanged(object sender, RibbonPropertyChangedEventArgs e)
    object m_Object = (object)e.NewValue;
I hope it works, but I'm not sure.
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
Message 7 of 10
moogalm
Autodesk Support
Autodesk Support
Please note RibbonCombo is not a CUI control it is a Windows Ribbon Runtime control, these UI changes are not persistent. Pl go through
http://adndevblog.typepad.com/autocad/2012/07/modify-ribbon.html
If you want Ribbon Combo Control on Ribbon Bar instead of Ribbon Toolbar, may be this should achieve your objective.
http://adndevblog.typepad.com/autocad/2012/06/ribbonsplitbutton-with-icons-images.html
Message 8 of 10
waseefur.rahman
Hi Madhukar,
I have downloaded the samples solution from the link you provided for creating Ribbion,
but getting error, attached a snap, could you please guide.
Message 9 of 10
moogalm
Autodesk Support
Autodesk Support
You need to migrate to latest and use .NET framework 4.6, and also refer AcCoreMgd.dll
I have attached migrated sample targetting .NET 4.6 and AutoCAD 2018.
Please let me know if any further queries.
Message 10 of 10
waseefur.rahman
Thanks both..
for your guidance..
any how I got the alternate,
but Looking for CUI Combobox in future...
