Creating Nested Block
Can Anyone help me with a sample code for creating nested blocks.
Thanks & Regards
philippe.leefsma
Hi
This sample creates a nested block that contains a circle, then a parent block that contains a block reference of the nested block:
[CommandMethod("NestedBlock")]
public void NestedBlock()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    Editor ed = doc.Editor;
    using (Transaction Tx = db.TransactionManager.StartTransaction())
        BlockTable bt = Tx.GetObject(db.BlockTableId, OpenMode.ForWrite)
            as BlockTable;
        BlockTableRecord btr = new BlockTableRecord();
        btr.Name = "ParentBlock";
        bt.Add(btr);
        Tx.AddNewlyCreatedDBObject(btr, true);
        BlockTableRecord btrNested = new BlockTableRecord();
        btrNested.Name = "NestedBlock";
        bt.Add(btrNested);
        Tx.AddNewlyCreatedDBObject(btrNested, true);
        Circle circle = new Circle(Point3d.Origin, Vector3d.ZAxis, 5.0);
        AddToBlock(circle, btrNested.ObjectId);
        BlockReference bref = new BlockReference(
            Point3d.Origin,
        AddToBlock(bref, btr.ObjectId);
        Tx.Commit();
private ObjectId AddToBlock(Entity entity, ObjectId btrId)
    using (Transaction tr = btrId.Database.TransactionManager.StartTransaction())
        try
            BlockTableRecord btr = tr.GetObject(
                btrId,
                OpenMode.ForWrite)
                    as BlockTableRecord;
            ObjectId id = btr.AppendEntity(entity);
            tr.AddNewlyCreatedDBObject(entity, true);
            tr.Commit();
            return id;
        catch (Autodesk.AutoCAD.Runtime.Exception ex)
            ErrorStatus es = ex.ErrorStatus;
            tr.Abort();
            return ObjectId.Null;
        catch (System.Exception ex)
            string error = ex.Message;
            tr.Abort();
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Thanks for your time but when I executed the code no circle is visible in the drawing but when I click block editor the circle is displayed in both blocks. Please see attached image.
philippe.leefsma
The circle is not visible because the final block is not inserted in the drawing. If you want to see it in model space, you would need either to use INSERT command or insert it programmatically. The circle is displayed in both block because NestedBlock is nested in the ParentBlock, so this is the expected behavior.
If you are a beginer with the AutoCAD API, I suggest you take a look first at the following resources:
http://www.youtube.com/watch?v=WYj0J-DrCSA
http://usa.autodesk.com/adsk/servlet/index?id=18162650&siteID=123112
http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-4E1AAFA9-740E-4097-800C-CAED09CDFF12...
Philippe.
Philippe Leefsma
That was great. The code that you gave answers what I asked for.
I was creating nested blocks so that when I take this file  in Navisworks I could see a heirarchal tree structure like:
GreateGrandfather
                            Grandfather
                                             Father
                                                     Child
                                                           Circle
But When I take this file in Navisworks I get the structure as:
GreateGrandfather
                           GreateGrandfather
                                                 Grandfather
                                                            Grandfather
        Father
        Father
        Child
        Child
        Circle
Please see the attached image[File in Navisworks]
Also When I try to run the code with some existing entity in the drawing and call AddToBlock with this existing entity as parameter in place of circlr its throws error eAlreadyindatabase at line :
tr.AddNewlyCreatedDBObject(entity, True)
And Yes you are right I have been in to programming from last 10 years but with AutoCAD API I have been working on and off for last 2 years.
