creating a JIGGED DIMENSION ojbect
a.kouchakzadeh
Message 1 of 1
a.kouchakzadeh
Hello every one.
Im struggling to create some jigged dimension objects.
my final aim is to create the jigged dimension in a way that when I run the command, the program appears two jigged dimensions, which move along with the cursor in a way that it detects the boundries by itself.
lets say the yellow cross is the cursor, and the white lines are the jigged dimension objects.
 now I move the cursor and it shows this:
 and when I click on the screen, it returns the dimensions as double so I can do some calculation on them.
is it possible at all?
I just noticed in the first picture I accidently ignored the door block. lets assume the jigged dimension didnt hit the door block.
TIA
EDIT: is it possible to make the dimension lines avoid block references? like if it hits the door, ignores the block reference?
Replies (0)
