Create SelectionSet VB.NET (filtered with conditions)
sgrya1
sgrya1
I need to create some filtered SelectionSets.
I converted this example as best as I am able for the filtering. Any comments on the conversion welcome.
http://through-the-interface.typepad.com/through_the_interface/2008/07/conditional-sel.html
Another example I found showed how to create a SelectionSet but it then converts it to an ObjectIdCollection for use.
Is there a difference betwen a SelectionSet and an ObjectIdCollection? They appear to be the same thing.
Public Sub SelectEntitiesWithProperties()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim ed As Editor = doc.Editor
Dim ent As Entity
Dim ss As Autodesk.AutoCAD.EditorInput.SelectionSet
Dim oIDs As ObjectIdCollection
Dim filter(10) As TypedValue
Try
filter(0) = New TypedValue(DxfCode.Operator, " filter(1) = New TypedValue(DxfCode.Operator, " filter(2) = New TypedValue(DxfCode.LayerName, "0")
filter(3) = New TypedValue(DxfCode.Start, "LINE")
filter(4) = New TypedValue(DxfCode.Operator, "and>")
filter(5) = New TypedValue(DxfCode.Operator, " filter(6) = New TypedValue(DxfCode.Start, "CIRCLE")
filter(7) = New TypedValue(DxfCode.Operator, ">=")
filter(8) = New TypedValue(DxfCode.Real, 10)
filter(9) = New TypedValue(DxfCode.Operator, "and>")
filter(10) = New TypedValue(DxfCode.Operator, "or>")
Dim sf As SelectionFilter = New SelectionFilter(filter)
Dim psr As PromptSelectionResult = ed.SelectAll(sf)
ss = psr.Value
If ss.Count > 0 Then
oids = New ObjectIdCollection(ss.GetObjectIds)
For Each oid In oids
ent = oid.GetObject(OpenMode.ForRead)
If TypeOf ent Is BlockReference Then
'br = CType(ent, BlockReference)
'Debug.Print(br.Name)
End If
Next
End If
Catch ex As System.Exception
MsgBox(ex.ToString)
End Try
End Sub
chiefbraincloud
There is a difference between a Selection Set and an ObjectIdCollection. If you do a For Each on a SelectionSet, the type of object you will be retrieving is SelectedObject, but there is limited information available from a SelectedObject, so most of the time you need to use the ObjectId to open the object to query or modify parameters.
sgrya1
Thanks Chiefbraincloud! I'm going to have to try to get my head around that one.
The same object needs to be put in a different context to allow it to be read from the database I guess.
Not sure the reason for a Selection Set now, but it doesn't appear as I can get to the ObjectIdCollection without using one.
Must be able to do colective actions on a selectionset.
Have to look into it... Edited by: sgrya1 on Mar 1, 2010 11:40 PM
{quote}
{quote}
Nonsense.
That's only the case if you don't understand how it
works, and how to use it.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
