Create Objects and then replace them with userinput
wbdehaan
wbdehaan
Hi, I Would like to create a drawing from vb.net, and when it is drawn, i would like to move it to the place the user wants it to be in the drawing using a ghost-image on the mouse cursus
... i cannot get it to work, my head explodes..(rather new at .net, used to vba)
this is what i have at this point:
I have a drawing, in this examples just 2 rectangles, which are drawn by vb.net, and put in an arraylist.
this arraylist has to be dragged to another location in the drawing by the user.
I want to get an objectcollection in a selectionset (or if anyone has a better idea??)
kind regards Wouter de Haan
Public Class Drag
Dim OriPunt AsPoint3d = Point3d.Origin
<Autodesk.AutoCAD.Runtime.CommandMethod("MD")> PublicSub MoveDrawing()
'--- draw 2 rectangles and add them to a arraylist
Dim GroepBoven AsNewArrayList
GroepBoven.Add(Cad_Teken.Rechthoek(10, 10, 100, 100))   '(result is an object)
GroepBoven.Add(Cad_Teken.Rechthoek(20, 50, 150, 150))
ModelspaceAdd(GroepBoven)
EndSub
Sub DragSelection(ByVal Collectie AsObjectIdCollection)
Dim ss As SelectionSet = SelectionSet.FromObjectIds(Collectie)
 ForEach id As ObjectId InCollectie
ss.add = SelectionSet.FromObjectIds(id)
Next
DragSelection(ss)
EndSub
Sub DragSelection(ByVal Objektid() AsObjectId)
' just drag one object (works)
Dim ss AsSelectionSet = SelectionSet.FromObjectIds(Objektid)
DragSelection(ss)
EndSub
Sub DragSelection(ByVal Selectieset AsSelectionSet)
Dim doc AsDocument = Application.DocumentManager.MdiActiveDocument
Dim db AsDatabase = doc.Database
Dim ed AsEditor = doc.Editor
Using tr AsTransaction = db.TransactionManager.StartTransaction
'---set de selectieset
ed.SetImpliedSelection(Selectieset)
'---bepaal bounding box en daarmee linkeronderhoek van selectie: NOG NIET GEDAAN
OriPunt = NewPoint3d(100, 100, 100)
'---Ask new location
Dim ppr As PromptPointResult = ed.Drag(Selectieset, vbLf & "Selecteer nieuwe locatie: ", New DragCallback(AddressOfMyDragCallback))
If (ppr.Status = PromptStatus.OK) Then
'--- Bepaal de translatiematrix
Dim mat AsMatrix3d = Matrix3d.Displacement(OriPunt.GetVectorTo(ppr.Value))
Dim currentSpace As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
'--- Verplaats alle onderdelen in de selectieset
ForEach selectedObj As SelectedObject InSelectieset
Dim selectedEntity As Entity = DirectCast(tr.GetObject(selectedObj.ObjectId, OpenMode.ForWrite), Entity)
selectedEntity.TransformBy(mat)
Next'--- Bevestig de transactie
tr.Commit()
EndIf
EndUsing
EndSub
PrivateFunction MyDragCallback(ByVal pt As Point3d, ByRef mat As Matrix3d) AsSamplerStatus
If (OriPunt = pt) Then'--- Als er geen wijziging is gemaakt, dit meldenReturnSamplerStatus.NoChange
Else'---Anders de transformatiematrix maken voor de verplaatsing
mat = Matrix3d.Displacement(OriPunt.GetVectorTo(pt))
EndIf
ReturnSamplerStatus.OK
End Function
End Class
Hallex
I just rewrote some parts of your code,
see if this will be working on your end
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices.Application
<Assembly: CommandClass(GetType(Global.MyProject.Drag))> '<-- change address here
Public Class Drag
    Dim OriPunt As Point3d = Point3d.Origin
    <Autodesk.AutoCAD.Runtime.CommandMethod("MD")> _
    Public Sub MoveDrawing()
        Dim GroepBoven() As ObjectId = New ObjectId(1) {}
        Dim id As ObjectId = CreateRectangle(New Point3d(0, 10, 0), New Point3d(100, 100, 0))
        GroepBoven(0) = id
        id = CreateRectangle(New Point3d(10, 10, 0), New Point3d(200, 200, 0))
        GroepBoven(1) = id
        Dim Selectieset As SelectionSet = SelectionSet.FromObjectIds(GroepBoven)
        DragSelection(Selectieset)
    End Sub
    Sub DragSelection(ByVal Selectieset As SelectionSet)
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Using tr As Transaction = db.TransactionManager.StartTransaction
            OriPunt = New Point3d(100, 100, 0) ''<--- point changed
            Dim ppr As PromptPointResult = ed.Drag(Selectieset, vbLf & "Selecteer nieuwe locatie: ", New DragCallback(AddressOf MyDragCallback))
                Dim mat As Matrix3d = Matrix3d.Displacement(OriPunt.GetVectorTo(ppr.Value))
                For Each selectedObj As SelectedObject In Selectieset
                Next '--- Bevestig de transactie
                tr.Commit()
            End If
        End Using
    End Sub
    Private Function MyDragCallback(ByVal pt As Point3d, ByRef mat As Matrix3d) As SamplerStatus
        If (OriPunt = pt) Then '--- Als er geen wijziging is gemaakt, dit meldenReturnSamplerStatus.NoChange
        Else '---Anders de transformatiematrix maken voor de verplaatsing
        End If
        Return SamplerStatus.OK
    End Function
    Public Function CreateRectangle(ByVal pt1 As Point3d, ByRef pt2 As Point3d) As ObjectId
        Dim pline As New Polyline(4)
        Dim id As ObjectId = ObjectId.Null
            Dim pts As New Point2dCollection()
            Dim p1 As Point2d = pt1.Convert2d(New Plane(Point3d.Origin, Vector3d.ZAxis))
            Dim p2 As Point2d = pt2.Convert2d(New Plane(Point3d.Origin, Vector3d.ZAxis))
            pts.Add(p1)
            pts.Add(New Point2d(p2.X, p1.Y))
            pts.Add(p2)
            pts.Add(New Point2d(p1.X, p2.Y))
            Dim i As Integer = 0
            For Each pt In pts
                pline.AddVertexAt(i, pts(i), 0, 0, 0)
                i += 1
            Next
            pline.Closed = True
            Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
            id = btr.AppendEntity(pline)
            tr.AddNewlyCreatedDBObject(pline, True)
            tr.Commit()
        End Using
        Return id
    End Function
End Class
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
