Create Layer and Line C#
k005
Advisor Advisor
Message 1 of 17
k005
Hello
I want to create a command that draws Line by Layer.
sample:
Layer name: Grobeton
Layer Color: 2
osnap : Intersection,MidPoint,EndPoint  = will be marked
and I will draw a line that will be active with this layer ... How can I do this?
Thanks.
Replies (16)
Message 2 of 17
essam-salah
Hi @k005
so you want to draw a line in a specific layer? and give it a specific color ?
and you want to programmatically activate 2D Object Snaps: Intersection, MidPoint, EndPoint?
Message 3 of 17
k005
Hi @essam-salah
Yes that's right
Message 4 of 17
essam-salah
@k005
so why you don't do it manually: set the current layer to the layer you want and OSnap you want?
what is the point?
give example please
Message 5 of 17
k005
for example :
I'll go over an existing drawing. and this will be on the layer I want. osnap, on the other hand, is just to activate object
capture for the moment. it is ok even if it is not ..
Message 6 of 17
essam-salah
@k005
not clear actually,
so try to give a real example with:
INPUT: ...
OUPUT: ...
Message 7 of 17
essam-salah
or screen shot
Message 8 of 17
k005
@essam-salah
I don't think screen recording is needed.
I just want to do this: create a layer that does not exist in the dwg file (give it color) and draw a line with it. so much.
osnap automatically catches the point I mentioned, better if it is activated.
Message 9 of 17
k005
@essam-salah
Even if the layer is present, it doesn't matter. let it occur again. according to the color I set
Message 10 of 17
essam-salah
@k005
got you
Message 11 of 17
essam-salah
hi @k005
try this:
using aApp = Autodesk.AutoCAD.ApplicationServices;
[CommandMethod("cieCreateLayer")]
        public static void CreateLayer()
            var doc = aApp.Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var editor = doc.Editor;
            // ask user for layer name
            var promptResult = editor.GetString("Layer Name:");
            if (promptResult.Status != PromptStatus.OK)
                editor.WriteMessage("\nNo String Found\n");
                return;
            string layerName = promptResult.StringResult;
            // set osnap
            aApp.Application.SetSystemVariable("OSMODE", 32); // Intersection
            aApp.Application.SetSystemVariable("OSMODE", 2); // Mid Point
            aApp.Application.SetSystemVariable("OSMODE", 1); // End Point
            using (var ts = db.TransactionManager.StartTransaction())
                // get layers table
                var layersTable = (LayerTable)ts.GetObject(db.LayerTableId, OpenMode.ForWrite);
                // create layer if not exist
                if (layersTable.Has(layerName) == false)
                    var newLayer = new LayerTableRecord();
                    newLayer.Name = layerName;
                    layersTable.Add(newLayer);
                    ts.AddNewlyCreatedDBObject(newLayer, true);
                // set color
                var layer = (LayerTableRecord)layersTable[layerName].GetObject(OpenMode.ForWrite);
                layer.Color = Color.FromRgb(255, 0, 0);
                // set current layer
                db.Clayer = layer.Id;
                // commit changes
                ts.Commit();
Message 12 of 17
essam-salah
@k005
just replace the osnap 3 lines with:
// set osnap
aApp.Application.SetSystemVariable("OSMODE", 32 | 2 | 1); // Intersection, Mid Point, End Point
just discovered Autodesk.AutoCAD.EditorInput.ObjectSnapMasks is a flags
Message 13 of 17
k005
Hi @essam-salah
so far...
only the command will not exit and the LINE command will run.
And it shouldn't ask for the layer name. It should be fixed.
So we will enter the layer names in C # code
Message 14 of 17
essam-salah
@k005
            string layerName = "Grobeton";
            // set osnap
                // get layers table
                // set color
                // commit changes
                ts.Commit();
            // send Line Cmd
            doc.SendStringToExecute("MULTIPLE LINE ", true, false, false);
Message 15 of 17
essam-salah
@k005
have you tried the last code?
Message 16 of 17
essam-salah
@k005
            // set osnap
                // get layers table
                // set color
                // commit changes
                ts.Commit();
            // send Line Cmd
Message 17 of 17
k005
@essam-salah
Thank you very much. 🤗
I will add a screenshot or a file in my next questions. 🤔
