Create block from SAT file
george1985
george1985
I would like to create a block in Autocad, by using an ACIS (.sat) file.
I would like to do this with the use of Autocad NET API.
Is there a sample code I can follow?
I found an older example of how .sat file can be imported.
However, I am getting an error 'eNotInDatabase' on the line:
        tran.AddNewlyCreatedDBObject(ACISEntity, true);
Does anyone have any suggestion, how I can create a block from a .sat file?
Any help is appreciated. Thank you in advance.
george1985
Any help how to import a SAT file with autocad NET api?
_gile
The following example creates a new block definition in the current drawing by importing a .sat file.
       [CommandMethod("TEST")]
        public void Test()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var fileDialog = new OpenFileDialog();
            fileDialog.Filter = "Acis file (*.sat)|*.sat";
            if (fileDialog.ShowDialog() != DialogResult.OK)
                return;
            string fileName = fileDialog.FileName;
            var promptResult = ed.GetString("\nEnter block name: ");
            if (promptResult.Status != PromptStatus.OK || string.IsNullOrWhiteSpace(promptResult.StringResult))
                return;
            string blockName = promptResult.StringResult;
            using (var tr = db.TransactionManager.StartTransaction())
                var blockTable = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                if (blockTable.Has(blockName))
                    return;
                tr.GetObject(db.BlockTableId, OpenMode.ForWrite);
                var btr = new BlockTableRecord { Name = blockName };
                blockTable.Add(btr);
                tr.AddNewlyCreatedDBObject(btr, true);
                var acisObjects = Body.AcisIn(fileName);
                foreach (DBObject dBObject in acisObjects)
                    if (dBObject is Entity)
                        btr.AppendEntity((Entity)dBObject);
                        tr.AddNewlyCreatedDBObject(dBObject, true);
                tr.Commit();
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
george1985
Thank you very much @_gile !
I learned a lot from your code.
Brilliant code.
