Create Arc with StartPoint EndPoint Radius?
[Managed ObjectARX 2007 with C#]
I am trying to create an arc with start point, end point, and radius.
So that if the arc gets drawn, I going to use the center point.
Well, I guess I can use "SendStringToExecute()" or "SendCommand()" and "ObjectAppended" eventhandler to get the arc object.
But this approach seems bit messy, so I am wondering if there is any other simple way.
hgasty1001
The problem is that the arc constructor use angles intead points, so you have to calculate the angles from the points, check this link: http://www.theswamp.org/index.php?topic=40382.msg456904#msg456904
Gaston Nunez
Alexander.Rivilis
Creating of arc with startpoint, endpoint and radius can not be unique. Such arcs can be either two or none.
Facebook | Twitter | LinkedIn
Expert Elite Member
As you would know AutoCAD already provides such feature. (Drawing Arc with Start point + End point + Radius).
So I was wondering if there is any API I can use.
It looks like I have to manually calculate angles and stuff.
Hmm.....
Hallex
Then you can to look at acedCmd and use the same command promts
as per as in ARC command , just an idea
Alexander.Rivilis
OK. Try this code (as usually minimum error checking done):
[CommandMethod("ARC2PR", CommandFlags.Modal)]
public static void Arc2PointsRadius()
  Document doc = Application.DocumentManager.MdiActiveDocument;
  Editor ed = doc.Editor;
  PromptPointResult pRes1 = ed.GetPoint("\nFirst point: ");
  if (pRes1.Status != PromptStatus.OK) return;
  PromptPointResult pRes2 = ed.GetPoint("\nSecond point: ");
  if (pRes2.Status != PromptStatus.OK) return;
  PromptDistanceOptions prDist =
	new PromptDistanceOptions("\nRadius: ");
  prDist.BasePoint = pRes2.Value;
  prDist.UseBasePoint = true;
  PromptDoubleResult rRes = ed.GetDistance(prDist);
  if (rRes.Status != PromptStatus.OK) return;
  Matrix3d ucsMat = ed.CurrentUserCoordinateSystem;
  Vector3d vNormal = ucsMat.CoordinateSystem3d.Zaxis;
  Point3d pStart = pRes1.Value.TransformBy(ucsMat); // Start point in WCS
  Point3d pEnd = pRes2.Value.TransformBy(ucsMat); // End point in WCS
  //  Finding center point of arc.
  CircularArc3d circ1 = new CircularArc3d(pStart, vNormal, rRes.Value);
  CircularArc3d circ2 = new CircularArc3d(pEnd, vNormal, rRes.Value);
  Point3d[] pts = circ1.IntersectWith(circ2);
  circ1.Dispose(); circ2.Dispose();
  if (pts.Length < 2) {
    ed.WriteMessage("\nInvalid arguments"); return;
  Point3d pCenter = pts[0];
  Vector3d v1 = pStart - pCenter, v2 = pEnd - pCenter;
  if (v1.CrossProduct(v2).DotProduct(vNormal) < 0) {
    pCenter = pts[1];
  CircularArc3d cCirc = new CircularArc3d(pCenter, vNormal, rRes.Value);
  double parStart = cCirc.GetParameterOf(pStart);
  double parEnd   = cCirc.GetParameterOf(pEnd);
  double parMid = (parStart + parEnd) * 0.5;
  Point3d pMid = cCirc.EvaluatePoint(parMid);
  cCirc.Dispose();
  CircularArc3d cArc = new CircularArc3d(pStart, pMid, pEnd);
  double angle =
	cArc.ReferenceVector.AngleOnPlane(new Plane(cArc.Center,cArc.Normal));
  Arc arc =
	new Arc(cArc.Center, cArc.Normal,
		cArc.Radius, cArc.StartAngle + angle,  cArc.EndAngle + angle);
  cArc.Dispose();
  using (Transaction tr = doc.TransactionManager.StartTransaction()) {
    BlockTableRecord btr =
	tr.GetObject(doc.Database.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
    btr.AppendEntity(arc);
    tr.AddNewlyCreatedDBObject(arc, true);
    tr.Commit();
Expert Elite Member
WOW!!!
Didn't expect the answer code.
It works great for me and it solves my problem.
Plus, I learned a lot from your code.
There are so many APIs I can utilize in ObjectARX.
Awesome!!
Thank you always~ 🙂
