Crashing when exporting large amount of points to csv vb.net
Message 1 of 11
Trying to export points to a csv with the object data that is attached to the point. I can use this and it works great for smaller projects, but crashes every time when I try to export a larg amount of points. The most it has successfully exported was 9000 points but on average it usually will get to 3000 points before i get a fatal error and everything crashes.
Dim CSV_FileName As String = Nothing
' navigate to the point text csv file using a file dialog
Dim dlg As New System.Windows.Forms.SaveFileDialog()
dlg.InitialDirectory = "C:\"
dlg.Filter = "csv excel files (*.csv)|*.csv|All files (*.*)|*.*"
If dlg.ShowDialog() = Windows.Forms.DialogResult.OK Then
CSV_FileName = dlg.FileName().ToString
End If
Dim oPoints As Autodesk.AECC.Interop.Land.AeccPoints
Dim sFilename As String
'Dim iCount As Integer
oPoints = oAeccDB.Points
sFilename = CSV_FileName
Dim inWriter As New StreamWriter(sFilename)
Dim pid, desc As String
Dim x, y, z As Double
Dim oPoint As Autodesk.AECC.Interop.Land.AeccPoint
Dim cnt As Long = oPoints.Count
Dim expline(cnt) As String
Dim n As Long
For n = 0 To cnt - 1
oPoint = oPoints.Item(n)
pid = oPoint.Number
x = oPoint.Easting
y = oPoint.Northing
z = oPoint.Elevation
desc = oPoint.RawDescription
Dim id As ObjectId = PointEntity.FromAcadObject(oPoint)
Dim tables As Tables
tables = HostMapApplicationServices.Application.ActiveProject.ODTables
Dim records As Records = tables.GetObjectRecords(Convert.ToUInt32(0), id, Constants.OpenMode.OpenForRead, False)
' Iterate through all records
Dim record As Record = records.Item(0)
'For Each record In records
Dim msg(12) As String
' Get the table
Dim table As ObjectData.Table = tables(record.TableName)
Dim str As String = Nothing
' Get record info
Dim i As Integer
Dim upbound As Integer = Record.Count - 1
For i = 2 To upbound - 1
Dim val As MapValue = Record(i)
Str = val.StrValue
msg(i - 1) = str
Next i
inWriter.WriteLine(pid & "," & y & "," & x & "," & z & "," & desc & "," & msg(1) & "," & msg(2) & "," & msg(3) & "," & msg(4) & "," & msg(5) & "," & msg(6) & "," & msg(7) & "," & msg(8) & "," & msg(9) & "," & msg(10) & "," & msg(11))
' Next
Next n
inWriter.Flush()
inWriter.Dispose()
End Sub
Replies (10)
Message 2 of 11
fieldguy
If autocad wants to send a crash report, you can use the "View files" option and view the ".dmp" file.  Scroll down to the section called "appdata".  You might see some more info on where/why the crash occurs.
If the problem occurs writing data to your csv file, you could try stringbuilder 1st.  Dump all of your point data into a stringbuilder, and then stream that to file.  You could also create large chunks with stringbuilder and write the chunks to file.
This is just a guess - I think it is obvious your code is OK.
Message 3 of 11
do not know how to read the .dmp files. I tried using the stringbuilder and it did speed up the export but it still crashes with large amount of numbers. I did a little more debugging and found that most of the time it crashed when it gets to the  line:
I tried removing that line and replacing my first for statement with
For Each oPoint In oAeccDB.Points
then it crashed at that line. Anymore suggestions?
Message 4 of 11
Hallex
Try create StringBulder and populate it with text lines
then write in in the csv file:
sw.Write (sb.ToString());
Iow, do it separatelly
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 5 of 11
fieldguy
You can view the dmp file with the button at the bottom - I think it says "View file contents".  Select the dmp file, then click on the view button.  It's been awhile since I have seen a crash report, but everything you need is on that dialog.
I am a map 3d user and have no experience with other verticals like Land Desktop.  Sorry!
Message 6 of 11
Thanks for your help finally got it to work with the stringbuilder. Here is my final code that worked.
<CommandMethod("exporter")> _
Public Sub ShowObjectDataInfo()
Try
If oAcadApp Is Nothing Then
oAcadApp = GetObject(, "AutoCAD.Application")
End If
Catch ex As System.Exception
ed.WriteMessage(ex.Message)
End Try
oAeccApp = oAcadApp.GetInterfaceObject("AeccXUiLand.AeccApplication.9.0")
oAeccDoc = oAeccApp.ActiveDocument
oAeccDB = oAeccApp.ActiveDocument.Database
End If
Dim builder As New StringBuilder
Dim desc As String
Dim pid As Integer
Dim oPoint As Autodesk.AECC.Interop.Land.AeccPoint = Nothing
pid = oPoint.Number
x = oPoint.Easting
y = oPoint.Northing
' Get the table
' Get record info
Dim i As Integer
Dim upbound As Integer = record.Count - 1
Dim val As MapValue = record(i)
str = val.StrValue
msg(i - 1) = str
Next i
builder.Append(pid & "," & y & "," & x & "," & z & "," & desc & "," & msg(1) & "," & msg(2) & "," & msg(3) & "," & msg(4) & "," & msg(5) & "," & msg(6) & "," & msg(7) & "," & msg(8) & "," & msg(9) & "," & msg(10) & "," & msg(11)).AppendLine()
Next
Dim s As String = builder.ToString
inWriter.WriteLine(s)
inWriter.Flush()
inWriter.Dispose()
builder.Clear()
GC.Collect()
End Sub
Message 7 of 11
Just noticed another bug. The drawing closes out ok but when I try to close out of Civil3d after running my command it crashes. Is there something that I am not closing or disposing of properly?
Message 8 of 11
Hallex
I recommend you to use in your code the following syntax
- Use Try ... Catch .. finally code block, it allow you to find
the problem points of code easily
- use Using.. End Using for all non-resident objects, e.g.:
using sw as SreamWriter= ....
sw.Write(...)
end using '' no need to close or dispose
same way for StringBuilder, i that case you don't have to Dispose
both of them as well
~'J'~
Message 9 of 11
Hallex
I just imagine how it would be, coz I haven't have Civil3d on my end
See code
        Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
        Dim oAcadApp As AcadApplication = Application.AcadApplication
        Try
            End If
        End Try
        Try
            dlg.RestoreDirectory = True
            End If
            Dim desc As String
            Dim pid As Integer
                pid = oPoint.Number
                x = oPoint.Easting
                y = oPoint.Northing
                    ' Get the table
                    ' Get record info
                    Dim i As Integer
                        str = val.StrValue
                        msg(i - 1) = str()
                    Next i
                    Dim rec As String = String.Format("{0}" + vbTab + "{1}" + vbTab + "{2}" + vbTab + "{3}" + vbTab + _
                                                      "{4}" + vbTab + "{5}" + vbTab + "{6}" + vbTab + "{7}" + vbTab + _
                                                      "{8}" + vbTab + "{9}" + vbTab + "{10}" + vbTab + "{11}" + vbTab + _
                                                      "{12}" + vbTab + "{13}" + vbTab + "{14}" + vbTab + "{15}",
                                                      pid, y, x, z, desc, msg(1), msg(2), msg(3), msg(4), msg(5), msg(6),
                                                      msg(7), msg(8), msg(9), msg(10), msg(11))
                    builder.AppendLine(rec)
                Next
                Using inWriter As New StreamWriter(sFilename)
                    inWriter.WriteLine(builder.ToString)
                    inWriter.Flush()
                End Using
                GC.Collect()
            MsgBox(ex.Message + vbLf + ex.StackTrace)
        Finally
        End Try
    End Sub
~'J'~
Message 10 of 11
That works great thanks for the code!
Message 11 of 11
Hallex
Glad to help,
Cheers Smiley Happy
~'J'~
