Counting instances of an image
btmsoftware
btmsoftware
Hi there,
I can find which images are attached to my current drawing with the following code. However, I don't know how to find out how many times they are attached.
Anybody ?
Using tr As Transaction = db.TransactionManager.StartTransaction
	Try
		Dim nod As DBDictionary
		Dim imageDict As DBDictionary
		Console.WriteLine("Getting ACAD_IMAGE_DICT DB dictionary")
		nod = CType(tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead, False), DBDictionary)
		imageDict = CType(tr.GetObject(nod.GetAt("ACAD_IMAGE_DICT"), OpenMode.ForRead, False), DBDictionary)
		For Each dicentry As DBDictionaryEntry In imageDict
			Dim myRasterImgDef As RasterImageDef = CType(tr.GetObject(CType(dicentry.Value, ObjectId), OpenMode.ForRead), RasterImageDef)
			If myRasterImgDef.IsLoaded Then
				Console.WriteLine("Found: " & myRasterImgDef.ActiveFileName)
				' NEED TO COUNT INSTANCES HERE
			Else
				Console.WriteLine("Not found: " & myRasterImgDef.SourceFileName)
			End If
		Next
		tr.Commit()
	Catch ex As Exception
		System.Windows.Forms.MessageBox.Show(ex.ToString, "Configurator", System.Windows.Forms.MessageBoxButtons.OK, System.Windows.Forms.MessageBoxIcon.Stop)
	End Try
End Using
 Thanx in advance
You need to search for raster reference entities of type RasterImage. There are two options I know for this, depending on your requirements: 1. Use Editor.SelectAll(), passing in a SelectionFilter with the appropriate dxf code. This is easiest but will only work in the current layout. Note: You might also need to zoom extents for this to work, i can't remember if you need to. 2. Iterate your block table records looking for RasterImage entities, using a counter. Advantage with this approach is that you can iterate your model space as well as all of your paper space block table records - i.e. you will get all of them.
btmsoftware
Will give option 2 a shot, seems the most appropriate indeed.
If you happen to have an example for this iteration ,great, if not, I'll figure it out by myself 😉
Virupaksha_aithal
Autodesk Support
Autodesk Support
Hi
Can you try DevBlog solution "Identifying number times a Raster Image is used in a drawing"
http://adndevblog.typepad.com/autocad/2012/05/identifying-number-times-a-raster-images-is-used-in-a-...?
Virupaksha aithal
Autodesk Devloper Network
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
btmsoftware
Exactly what I needed, thanx a lot
