Copying and pasting XData between drawings
SRSDS
Advisor Advisor
SRSDS
Hi again,
How can know if entities are being manually copied and pasted between drawings.
A thought is to add a GUID to each entities Xdata and check if the value is in the named object dictionary.
Alfred.NESWADBA
good idea, but copying the drawing (with file-copy) is not prevented with this way.
Not as criticism, just as info to think of it!
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
SRSDS
ohh.. good point!
I will read the filename also as a second measure. Filenames might be the same as well but both would be rare.
Or maybe the file creation date and time.
Probably no need to write anything as data. I just need to read the identifiers during copy and paste to see if they don't match.
Thanks again.
Alfred.NESWADBA
not sure what your global direction is. For me and my way of work, the filename is used as variable as possible.
1) On one side I save with a drawing-name ending with 2-4 digits as version-number and from time to time I do a _SAVEAS and increase the number.
2) On the other side, I transfer the files between computers (e.g. to home-office), continue to work and then copy it back (will be an allowed copy?)
3) not to forget, what if you get a file back by restoring from a backup-system (also allowed filecopy, isn't it?)
...and I think that there are a lot more reasons to copy a file and it sould be also valid out of your sight.
I think (without something like a data-managementserver, where the files are not stored in a filessystem you can directly access) it will not be possible to handle a filecopy with data stored within the DWG-file, that on one side allows the above variations but limit some - from your point of view - "not allowed"mechanism of copying.
Within the dataserver you have document-id's that give you the possibility of using a unique-id that you cannot get from a filesystem. However, also handling that with the fileserver is a challange.
Maybe you could describe more of "for what reason" are you doing that, then there may come some better ideas than this one.
- alfred -
Alfred NESWADBA
SRSDS
I really just need to know if the objects being pasted into a drawing have been copied from the same drawing.
COPYBASE command is the only event I need to consider.
I’ll tell users that other methods like inserting a drawing as a block then exploding isn't supported.
Maybe the file creation date and time is a good unique identifier to monitor.
Dim FileCreationTime As String = File.GetCreationTime(db.Filename())
Alfred.NESWADBA
I even don't know what type of copy is now allowed, sorry. Why do you have to watch only _COPYBASE, there is also _COPYCLIP and also I think that not creating the copy-buffer will be the problem but the _PASTE*-methods have to be watched (or is it also not allowed to create a copy of geometry into MS-Word for documentation?).
The file-creation-date will also fail with my above types (backup-restore/copy to home-office/version-numbering).
And if you write EEDs and NOD, how will you handle the situation of home-work? Will you ensure that the home-pc will also run your application every time AutoCAD starts (and with any AutoCAD-profile and ...)
Now, after reading that .... all I'm writing look so pessimistic. Please understand that just as ideas, not as "all is nonesens"!
- alfred -
Alfred NESWADBA
SRSDS
Hi Alfred.
Sorry. First time I've done this and have no experience at all.
I personally only use COPYBASE between drawings. I wasn't thinking about COPYCLIP or CUTCLIP but will now.
Filename including the path should solve the drawing identification problem I think (checking source dwg = destination dwg). Two open drawings will never the same filepath & filename.
