copy page setup from another file
Any idea why the following code doesn't work?  The important/significant lines are toward the end in a for . . . next loop.
Private Sub subCopyPageSetupFromFile()
Dim strDrvPathFileExt As String
Dim objSrcDB As New Database
Dim objTransactionManager As Autodesk.AutoCAD.DatabaseServices.TransactionManager
Dim objTransaction As Transaction
Dim objSrcPlotSettingsDictionary As DBDictionary
Dim objDictionaryEntry As DictionaryEntry
Dim objPlotSettings As PlotSettings
strDrvPathFileExt = "C:\ProgramData\Autodesk\ApplicationPlugins\Acad.dwt"
objSrcDB.ReadDwgFile(strDrvPathFileExt, FileOpenMode.OpenForReadAndReadShare, True, "")
objTransactionManager = objSrcDB.TransactionManager
objTransaction = objTransactionManager.StartTransaction
objSrcPlotSettingsDictionary = objTransaction.GetObject(objSrcDB.PlotSettingsDictionaryId, OpenMode.ForRead)
For Each objDictionaryEntry In objSrcPlotSettingsDictionary
objPlotSettings = objTransaction.GetObject(objDictionaryEntry.Value, OpenMode.ForRead)
MsgBox(objDictionaryEntry.Key.ToString.ToUpper)
Next
objTransaction.Dispose()
objTransactionManager.Dispose()
SENL1362
DeletePlotSettings(db);
            using (var sourceDb = new Database(false, true))
                sourceDb.ReadDwgFile(plotSettingsPathname, FileOpenMode.OpenForReadAndReadShare, true, null);
                using (var trSource = sourceDb.TransactionManager.StartTransaction())
                    using (var tr = db.TransactionManager.StartTransaction())
                        var sourcePlotSettingsDict = (DBDictionary)trSource.GetObject(sourceDb.PlotSettingsDictionaryId, OpenMode.ForRead);
                        foreach (DBDictionaryEntry sourcePlotSettingsDictEntry in sourcePlotSettingsDict)
                            var sourcePlotSettings = (PlotSettings)trSource.GetObject(sourcePlotSettingsDictEntry.Value, OpenMode.ForRead);
                            var plotSettings = new PlotSettings(sourcePlotSettings.ModelType);
                            plotSettings.CopyFrom(sourcePlotSettings);
                            plotSettings.AddToPlotSettingsDictionary(db);
                            tr.AddNewlyCreatedDBObject(plotSettings, true);
                        tr.Commit();
                    trSource.Commit();
public static void DeletePlotSettings(Database db)
                var plotSettingsDict = (DBDictionary)tr.GetObject(db.PlotSettingsDictionaryId, OpenMode.ForRead);
                using (var psIdsToRemove = new ObjectIdCollection())
                    foreach (DBDictionaryEntry plotSettingsDictEntry in plotSettingsDict)
                        psIdsToRemove.Add(plotSettingsDictEntry.Value);
                    foreach (ObjectId psId in psIdsToRemove)
                        var plotSettings = (PlotSettings)tr.GetObject(psId, OpenMode.ForWrite);
                        plotSettings.Erase();
                tr.Commit();
