Copy object inside same drawing... problems
I've been using this method for "copying" objects from one point to another..
Dim EntityCopy As Entity = EntitySource.GetTransformedCopy(Matrix3d.Displacement(startPT.GetVectorTo(EndPT)))
But have run into a few glitches, not program stopping glitches just annoying ones..
With polylines, not all the properties are copied, one for example is the "global width".  it gets re-set to 0.
Problem is with dynamic blocks..  the above method creates a "dumb" version of the block rather than a functional dynamic version of the block..
Can anyone show me a way to fix this, or an alternate method for copying objects from point a to point b?
Hallex
In that case as for  Tony Tanzillo's recomendation I wouldt use
DeepCloneObjects method of DataBase instead
Try this quicky
No error trapping in there, do it by yourself
    <CommandMethod("como")> _
    Public Shared Sub CopyMove()
        Dim doc As Document = acApp.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim peo As New PromptEntityOptions(vbLf & "Select object:")
        Dim per As PromptEntityResult = ed.GetEntity(peo)
        If per.Status <> PromptStatus.OK Then
            Return
        End If
        Dim startPT As Point3d = ed.GetPoint(vbCr & "Pick a point from: ").Value
        Dim EndPT As Point3d = ed.GetPoint(vbCr & "Pick a point to: ").Value
        Using tr As Transaction = db.TransactionManager.StartTransaction()
            Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
            Dim sourceId As ObjectId = per.ObjectId
            Dim EntitySource As Entity = CType(tr.GetObject(sourceId, OpenMode.ForRead), Entity)
            Dim ids As New ObjectIdCollection()
            ids.Add(sourceId)
            db.DeepCloneObjects(ids, db.CurrentSpaceId, New IdMapping, False)
            Dim EntityCopy As Entity = CType(tr.GetObject(ids(0), OpenMode.ForRead), Entity)
            EntityCopy.UpgradeOpen()
            EntityCopy.TransformBy(Matrix3d.Displacement(startPT.GetVectorTo(EndPT)))
            EntityCopy.ColorIndex = 2
            tr.Commit()
        End Using
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Thank you, that is perfect. 🙂
Hallex
You're welcome 🙂
Glad to help
Oleg
~'J'~
MRiemenCAD
Working with making blocks from existing entities in a file. I've run into problems with iterating through the entities within a selection set and writing them to my new blocktablerecord. How do I take those items from my selection set and add them to this new block? All thoughts and help are appreciated.
BKSpurgeon
For the benefit future readers:
Just create a new block table record rather than adding it to the model space block table record. I think i know what i'm doing, but i'll let the more experienced autocad developers tweak the code. This is some quick and dirty code which i previously wrote.
I suspect that the following is a shallow copy though - change to a deep one as you see fit.
      private static void CloneAndTrasnformTheObjects(PromptPointResult PPRbasePoint, PromptPointResult PPRdestinationPoint, SelectionSet ss)
            // Get the transformation vector to apply to all cloned objects
            Point3d pointBase = PPRbasePoint.Value;
            Point3d pointDestination = PPRdestinationPoint.Value;
            Vector3d transformationVector = pointBase.GetVectorTo(pointDestination);
            // get the entites which we want to clone
            ObjectIdCollection entitiesToCopy = new ObjectIdCollection(ss.GetObjectIds());
            //set up the document/database/editor
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            using (DocumentLock docLock = doc.LockDocument())
                using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                    // clone the following objects
                    foreach (ObjectId id in entitiesToCopy)
                        BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                        BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                        Entity entityOriginal = tr.GetObject(id, OpenMode.ForRead) as Entity;
                        Entity entityClone = entityOriginal.Clone() as Entity;
                        // ensuring we have no null values
                        if (entityClone != null && entityOriginal != null && bt != null && btr != null)
                            entityClone.TransformBy(Matrix3d.Displacement(transformationVector));
                            btr.AppendEntity(entityClone);
                            tr.AddNewlyCreatedDBObject(entityClone, true);
                    tr.Commit();
rgds
BK
