Copy Linetype from Another Database
Message 1 of 9
Here is my situation:
I have 1 drawing open, I have another drawings Database open
I have found the LinetypeTableRecord (in the Database) of the line type I want to copy to the open drawing.
The Question:
How do I copy a LinetypeTableRecord from one drawing to another?
any examples would be helpfull.
Replies (8)
Message 2 of 9
Ok, here's the track I am on now. Im not sure its the right track mind you!
I think I have to use DeepClone, so here is what I tried:
Database db = HostApplicationServices.WorkingDatabse;
ObjectIdCollection vObjs = newObjectIdCollection();
vObjs(0) = Object Id of linetype I want to copy
db.DeepCloneObjects(vObjs,?????,false);
Now IF I am on the right track what goes where the ????? are?
The help says ObjectId is required there but ID of what? The LineTypeTable? (I tried that and it didn't work).
Message 3 of 9
db.WblockCloneObjects(...)
Message 4 of 9
I am using Database.WblockCloneObjects() to copy linetypes from external drawing. It works fine if linetype doesn't have a reference to complied shape file (.shx). If it does, linetypes are copied without shape-referenced part (e.g. geometries like rounds).
Is there any solution?
Message 5 of 9
fenton_webb
Is there a reason why you can't just use LoadLinetype()?
http://through-the-interface.typepad.com/through_the_interface/2010/03/loading-multiple-linetypes-in...
Fenton Webb
AutoCAD Engineering
Message 6 of 9
Yes, I am using drawing templates to load all the stuff for my current drawing.
Actually, now I have switched to loading line types from file, but it'd be good for me to load from *.dwt.
Message 7 of 9
fenton_webb
Just use Database.Insert("dwtFile.dwt",,,)
Fenton Webb
AutoCAD Engineering
Message 8 of 9
Are you shure about this?
There are three overloads and only two of them accept string parameters, which are blockName from another database, as I understand:
public void Insert(Matrix3d transform, Database dataBase, bool preserveSourceDatabase);
public ObjectId Insert(string blockName, Database dataBase, bool preserveSourceDatabase);
public ObjectId Insert(string sourceBlockName, string destinationBlockName, Database dataBase, bool preserveSourceDatabase);
Message 9 of 9
fenton_webb
Something like this http://forums.augi.com/showthread.php?145986-Insert-External-DWG-file-with-attributes
Fenton Webb
AutoCAD Engineering
