Copy layer from another DWG in c#
alexisgacia
alexisgacia
Good day. I'm searching a code to copy a layer from dwg to current. I did some testing code from the net and I was not able to figure it out the right solution.
Please share working code on copying a layer either vb or C#
Thank you very much in advance
kerry_w_brown
The code will vary depending if the source drawing is open in AutoCAD or not.
Will the user have a choice of the source drawing ? or will the source be constant ?
Judicious use of Google should provide several possible solutions.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
alexisgacia
The path is a constant.
The function looks like below, but I wasn't able to figure out to properly copy the layer to the current drawing:
public boolean GetLayerFromLib(LayerName as string)
string dwgPath = @"c:\test.dwg";
'open dwgPath database
'read the LayerTable
'Check if has the LayerName
'if exist copy to current database and return true
'else return false
_gile
Here's an example:
        public bool GetLayerFromLib(string layerName)
            var curDb = HostApplicationServices.WorkingDatabase;
            using (var db = new Database(false, true))
                db.ReadDwgFile(dwgPath, FileOpenMode.OpenForReadAndAllShare, true, null);
                using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                    var layerTable = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
                    if (!layerTable.Has(layerName))
                        return false;
                    var ids = new ObjectIdCollection();
                    ids.Add(layerTable[layerName]);
                    var mapping = new IdMapping();
                    db.WblockCloneObjects(ids, curDb.LayerTableId, mapping, DuplicateRecordCloning.Replace, false);
                    return true;
Gilles Chanteau
GileCAD
GitHub
alexisgacia
It works!
Thank you very much.
